Lights
UI | Native Name | V-Ray Plugin Name | Support | |
Standard Maya Lights
| Type: Ambient Light Area Light Directional Light Point Light Spot Light Volume Light |
LightAmbient LightRectangle MayaLightDirect LightOmni LightSpot – |
Color | color | |||
Intensity | color | |||
Illuminates by Default | – | |||
Ambient Shade | LightAmbient/ambient_shade | |||
Emit Diffuse | affectDiffuse | |||
Emit Specular | affectSpecular | |||
Decay Rate: No Decay Linear Quadratic Cubic |
decay=0 decay=1 decay=2 decay=3 |
Cone Angle | LightSpot/coneAngle | |||
Penumbra Angle | LightSpot/penumbraAngle | |||
Dropoff | LightSpot/dropOff | |||
Normalize | – | |||
Light Shape: Box Sphere Cylinder Cone |
(Ambient Light only) | Shadow Color | shadowColor | ||
Use Ray Trace Shadows | shadows | |||
Shadow Radius | shadowRadius | |||
Shadow Rays | shadowSubdivs | |||
Ray Depth Limit | – | |||
(Directional Light only) | Use Depth Map Shadows | – | ||
Light Radius | shadowRadius | |||
Light Angle | shadowRadius | |||
(Spot Light only) | Light Fog | – | ||
Fog Spread | – | |||
Fog Intensity | – | |||
Light Glow | – | |||
Intensity Curve | – | |||
Color Curves | – | |||
Barn Doors: Left Barn Door Right Barn Door Top Barn Door Bottom Barn Door | barnDoor barnDoorLeft barnDoorRight barnDoorTop barnDoorBottom | |||
Use Decay Regions | useDecayRegions | |||
Start Distance1 | startDistance1 | |||
End Distance1 | endDistance1 | |||
Start Distance2 | startDistance2 | |||
End Distance2 | endDistance2 | |||
Start Distance3 | startDistance3 | |||
End Distance3 | endDistance3 |
V-Ray Lights | V-Ray Dome Light | LightDome | ||
Enabled | enabled | |||
Color Mode: Color Temperature |
Light Color | color | |||
Temperature | color | |||
Intensity multiplier | intensity | |||
Dome Spherical | dome_spherical | |||
Dome Adaptive | dome_adaptive | |||
Use Dome Tex | use_dome_tex | |||
Multiply By The Light Color | dome_tex/TexAColorOp/mode=2 | |||
Dome Tex | dome_tex | |||
Dome Tex A | dome_tex/TexAColorOp/result_alpha | |||
Invisible | invisible | |||
Affect Diffuse | affectDiffuse | |||
Diffuse contribution | diffuse_contribution | |||
Affect Specular | affectSpecular | |||
Specular contribution | specular_contribution | |||
Affect Rreflections | affectReflections | |||
Affect Alpha | affect_alpha | |||
Light cut-off threshold | cutoffThreshold | |||
Texture resolution | tex_resolution | |||
Shadow bias | shadowBias | |||
Shadow color | shadowColor | |||
Terget radius | dome_targetRadius | |||
Emit distance | dome_emitRadius | |||
Caustics subdivs | causticSubdivs | |||
Caustics multiplier | causticMult | |||
V-Ray Rectangular Light | VRayLightRect | |||
Toggle Target | – | |||
Units: default Lumens lm/m/m/sr Watts w/m/m/sr |
units=0 units=1 units=2 units=3 units=4 |
Shape Type: Rectangle Disc |
is_disk=0 is_disk=1 |
U size | u_size | |||
V size | v_size | |||
Directional | directional | |||
Directional Preview Length | – | |||
Directional Preview: Selected Always Never |
Use Rect Tex | use_rect_tex | |||
Multiply By The Light Color | rect_tex/TexAColorOp/mode=2 | |||
Rect Tex | rect_tex | |||
Rect Tex A | rect_tex/TexAColorOp/result_alpha | |||
Show in viewport: Disabled Texture only Texture*Intensity |
No Decay | noDecay | |||
Double Sided | doubleSided | |||
Affect Reflections | affectReflections | |||
Override motion blur samples | – | |||
Motion blur samples | – | |||
Shadows bias | shadowBias | |||
Shadows color | shadowColor | |||
Locator scale | – | |||
V-Ray Sphere Light | VRayLightSphere | |||
Radius | u_size | |||
Sphere segments | sphere_segments | |||
Affct Diffuse | affectDiffuse | |||
V-Ray IES Light | LightIES | |||
Enabled | enable | |||
IES File Name | ies_file | |||
Lights Color | color | |||
Filter color | filter_color | |||
Intensity | power | |||
Soft Shadows | soft_shadows | |||
Area Specular | area_speculars | |||
Local scale | – | |||
Light Shape | ies_light_shape | |||
Width | ies_light_width | |||
Length | ies_light_length | |||
Height | ies_light_height | |||
Diameter | ies_light_diameter | |||
V-Ray Mesh Light | VRayLightMesh | |||
Use Texture | use_tex | |||
Texture | tex | |||
Texture Alpha | tex/TexAColorOp/result_alpha | |||
Cache Texture | cache_tex | |||
Light cut-off threshold | causticSubdivs | |||
Texture Resolution | tex_resolution | |||
Causics subdivs | causticSubdivs | |||
V-Ray Sun | SunLight | |||
Intensity multiplier | intensity_multiplier | |||
Turbidity | turbidity | |||
Ozone | ozone | |||
Size multiplier | size_multiplier | |||
Sky Model: Hosek et al. Preetham et al. CIE Clear CIE Overcast Improved |
sky_model.0 sky_model=1 sky_model=2 sky_model=3 sky_model=4 |
Horiz Illumination | horiz_illum | |||
Color Mode: Filter Direct Override |
color_mode=0 color_mode=1 color_mode=2 |
Filter Color | filter_color | |||
Ground Albedo | ground_albedo | |||
Blend Angle | blend_angle | |||
Horizon Offset | horizon_offset | |||
Cast shadows from environment | – | |||
Shadow Color | shadowColor | |||
Photon radius | photon_radius | |||
Caustics multilpier | causticMult |
Camera
Maya Camera
| Camera | RenderView | ||
Controls: Camera Camera and Aim Camera, Aim and Up |
Angle of View | fov | |||
Focal Length | mayaFocalLength | |||
Camera Scale | zoom | |||
Auto Render Clip Plane | – | |||
Near Clip Plane | RenderView/clipping_near | |||
Far Clip Plane | RenderView/clipping_far | |||
Film Gate: | – | |||
Camera Aperture (inch) | mayaApperture | |||
Camera Aperture (mm) | – | |||
Film Aspect Ratio | – | |||
Lens Squeeze Ratio | – | |||
Fit Resolution Gate: Fill Horizontal Vertical Overscan |
Film Fit Offset | – | |||
Film Offset | – | |||
Shake Enabled | – | |||
Shake | – | |||
Shake Overscan Enabled | – | |||
Shake Overscan | – | |||
Pre Scale | – | |||
Film Translate | – | |||
Film Roll Pivot | – | |||
Film Roll Value | – | |||
Film Roll Order: Rotate-Translate Translate-Rotate |
Post Scale | – | |||
Depth of Field | – | |||
Focus Distance | – | |||
F Stop | – | |||
Focus Region Scale | – | |||
Background Color | ||||
Image Plane | ||||
Shutter Angle | – | |||
Orthographic | orthographic | |||
Orthographic Width | orthographicWidth | |||
V-Ray Physical Camera
| Physical Camera | CameraPhysical | ||
Treat as VRay Physical camera | ||||
Type: Still camera Cinematic camera Video camera |
type=0 type=1 type=2 |
Film gate (in mm) | film_width | |||
Focal length (in mm) | focal_length | |||
Specify FOV: Off Specify From Maya camera |
specify_fov=0 specify_fov=1 – |
FOV | fov | |||
Zoom factor | zoom_factor | |||
Distortion type: Quadratic Cubic Lens file Texture |
distortion_type=0 distortion_type=1 distortion_type=2 distortion_type=3 |
Distortion amount | distortion | |||
LENS File | lens_file | |||
Distortion map | distortion_tex | |||
F-number | f_number | |||
Horizontal lens shift | horizontal_shift | |||
Vertical lens shift | lens_shift | |||
Guess vertical lens shift | – | |||
Shutter speed | shutter_speed | |||
Shutter angle | shutter_angle | |||
Shutter offset | shutter_offset | |||
Latency | latency | |||
ISO | ISO | |||
Specify focus | specify_focus | |||
Focus distance | focus_distance | |||
Exposure color correction: No Exposure Physical Exposure Exposure Value |
exposure=0 exposure=1 exposure=2 |
White balance | white_balance | |||
Exposure Value | exposure_value | |||
Enable vignetting effect | vignetting | |||
Vignetting amount | vignetting | |||
Enable Bokeh effects | blades_enable | |||
Number of blades | blades_num | |||
Blades rotation (in radians) | blades_rotation | |||
Center bias | center_bias | |||
Bokeh anisotropy | anisotropy | |||
Enable Depth of field | use_dof | |||
Enable Motion blur | use_moblur | |||
Aperture map | bmpaperture_tex | |||
Affect exposure | bmpaperture_affects_exposure | |||
Cat's eye bokeh | optical_vignetting | |||
Rolling shutter mode: Disabled Top to bottom Bottom to to Left to right Right to left |
rolling_shutter_mode=0 rolling_shutter_mode=1 rolling_shutter_mode=2 rolling_shutter_mode=3 rolling_shutter_mode=4 |
Rolling shutter duration | rolling_shutter_duration |
Geometry
V-Ray Clipper | VRayClipper | |
V-Ray Displacement | GeomDisplacedMesh GeomStaticSmoothedMesh | |
V-Ray Fur | GeomHair | |
V-Ray Instancer | Instancer | |
V-Ray MetaBall | – | |
V-Ray Plane | GeomPlane | |
V-Ray Proxy | GeomMeshFile | |
V-Ray Renderable Curve | ||
V-Ray Scene | VRayScene | |
V-Ray VolumeGrid | PhxShaderSimVol |
Materials
V-Ray Al Surface | BRDFALSurface |
VRayBlendMtl | BRDFLayered |
VRayBumpMtl | BRDFBump |
VRayCarPaintMtl | BRDFCarPaint |
VRayCarPaint2Mtl | BRDFCarPaint2 |
VRayLightMtl | BRDFLight |
BRDFScatterVolume (from plugin) | BRDFScatterVolume |
VRayFastSSS2 | BRDFSSS2Complex |
VRayStochasticFlakesMtl | BRDFStochasticFlakes |
Two Sided | Mtl2Sided |
VRayToonMtl | BRDFToonMtl | Loads as BRDFVRayMtl, toon parameters are ignored. |
VRayPointParticleMtl | BSDFPointParticle | Loads as a simple diffuse BRDF. |
VRayMtl
UI | Native name | V-Ray plugin Name (plugin/parameter) | Support |
VRayMtl | BRDFVRayMtl | ||
Diffuse Color | diffuse | ||
Diffuse Texture | diffuse | ||
Diffuse Amount | diffuse/TexAColorOp/mult_a | ||
Diffuse Amount Texture | diffuse/TexAColorOp/mult_a | ||
Opacity Map | opacity_color | ||
Opacity Map Texture | opacity_color | ||
Opacity Mode: Normal Clip Stochastic |
opacity_mode=0 opacity_mode=1 opacity_mode=2 | ||
Roughness Amount | roughness | ||
Roughness Amount Texture | roughness | ||
Self-Illumination | self_illumination | ||
Self-Illumination Texture | self_illumination | ||
Self-Illumination GI | self_illumination_gi | ||
Compensate exposure | compensate_camera_exposure | ||
| BRDF Type: Phong Blinn Ward Microfacet GTR (GGX) |
brdf_type=0 brdf_type=1 brdf_type=2 brdf_type=4 |
Reflection Color | reflect | ||
Reflection Color Texture | reflect | ||
Reflection Amount | reflect/TexAColorOp/mult_a | ||
Refection Amount Texture | reflect/TexAColorOp/mult_a | ||
Reflection glossiness | reflect_glossiness | ||
Reflection glossiness Texture | reflect_glossiness | ||
Reflection subdivs | reflect_subdivs | ||
Use Fresnel | fresnel | ||
Glossy Fresnel | option_glossy_fresnel | ||
Lock Fresnel IOR To Refraction IOR | fresnel_ior_lock | ||
Fresnel IOR | fresnel_ior | ||
Fresnel IOR Texture | fresnel_ior | ||
GGX tail falloff | gtr_gamma | ||
Metalness | metalness | ||
Metalness Texture | metalness | ||
Use roughness | roughness_model | ||
Anisotropy | anisotropy | ||
Anisotropy Texture | anisotropy | ||
Anisotropy Rotation | anisotropy_rotation | ||
Anisotropy Rotation Texture | anisotropy_rotation | ||
UV Vectors Derivation: Local object axis Specified uvw generator |
anisotropy_derivation=0 anisotropy_derivation=1 |
Local Axis: X Y Z |
anisotropy_axis=0 anisotropy_axis=1 anisotropy_axis=2 |
Anisotropy UV Coord | anisotropy_uvwgen | ||
| Trace Reflections | reflect_trace | |
Max depth | reflect_depth | ||
Dim distance On | reflect_dim_distance_on | ||
Dim distance | reflect_dim_distance | ||
Dim fall off | reflect_dim_distance_falloff | ||
Reflect On Back Side | option_reflect_on_back | ||
Affect Channels: Color only Color+alpha All Channels |
reflect_affect_alpha=0 reflect_affect_alpha=1 reflect_affect_alpha=2 |
Coat Color | coat_color | ||
Coat Color Texture | coat_color | ||
Coat Amount | coat_amount | ||
Coat Amount Texture | coat_amount | ||
Coat Glossiness | coat_glossiness | ||
Coat Glossiness Texture | coat_glossiness | ||
Coat IOR | coat_ior | ||
Coat IOR Texture | coat_ior | ||
Lock Coat Bump Map To Base Bump | coat_bump_lock | ||
Coat Bump Map Type | coat_bump_type | ||
Coat Bump Map | coat_bump_map | ||
Coat Bump Map Texture | coat_bump_map | ||
Coat Bump Mult. | coat_bump_amount | ||
Coat Bump Mult. Texture | coat_bump_amount | ||
Refraction Color | refract | ||
Refraction Color Texture | refract | ||
Refraction Color Amount | refract/TexAColorOp/mult_a | ||
Refraction Color Amount Texture | refract/TexAColorOp/mult_a | ||
Refraction Glossiness | refract_glossiness | ||
Refraction Glossiness Texture | refract_glossiness | ||
Refraction IOR | refract_ior | ||
Refraction IOR Texture | refract_ior | ||
Fog Color | fog_color | ||
Fog Color Texture | fog_color_tex | ||
Fog multiplier | fog_mult | ||
Fog bias | fog_bias | ||
Affect Shadows | refract_affect_shadows | ||
Thin-walled | refract_thin_walled | ||
Translucency: None Volumetric SSS |
translucency=0 translucency=4 translucency=6 |
SSS Amount | translucency_amount | ||
SSS Amount Texture | translucency_amount | ||
Scatter Color | translucency_color | ||
Scatter Color Texture | translucency_color | ||
Depth (cm) | fog_mult | ||
| Trace Refractions | refract_trace | |
Max depth | refract_depth | ||
refract_affect_alpha=0 refract_affect_alpha=1 refract_affect_alpha=2 |
Dispersion | dispersion_on | ||
Dispersion Abbe | dispersion | ||
Sheen Color | sheen_color | ||
Sheen Color Texture | sheen_color | ||
Sheen Amount | sheen_color/TexAColorOp/mult_a | ||
Sheen Amount Texture | sheen_color/TexAColorOp/mult_a | ||
Sheen Glossiness | sheen_glossiness | ||
Sheen Glossiness Texture | sheen_glossiness | ||
Map Type: Bump Map Normal Map in tangent space Normal Map in object space Normal Map in screen space Normal Map in world space Local space bump map |
bump_type=0 bump_type=1 bump_type=2 bump_type=3 bump_type=4 bump_type=5 |
Bump Map | bump_map | ||
Bump Mult | bump_amount | ||
Bump Mult Texture | bump_amount | ||
Bump Delta Scale | BRDFBump/bump_delta_scale | ||
Bump Delta Scale Texture | BRDFBump/bump_delta_scale | ||
Cutoff Threshold | option_cutoff | ||
Double-sided | option_double_sided | ||
Use Irradiance Map | option_use_irradiance_map | ||
Fix dark edges | option_fix_dark_edges |
Maps
Native Name | V-Ray Plugin Name | Support | Note | |||
2D Textures | V-Ray | VRay Dirt | TexDirt | |||
VRay Edges | TexEdges | |||||
VRay Falloff | TexFalloff, TexOutput | Not supported in bump mapping | ||||
VRay Fresnel | TexFresnel | Not supported in bump mapping | ||||
VRayInverseExposure | ||||||
VRay Layered Tex | TexLayeredMax | Not supported in bump mapping | ||||
VRay Multi Sub Tex | TexMulti | Not supported in bump mapping | ||||
VRay Ray Switch | TexRaySwitch | |||||
VRay Softbox | TexSoftbox | |||||
VRay Temperature | TexTemperature | |||||
VRayGLSL | ||||||
VRay Tex OCIO | TexOCIO | |||||
VRay Vertex Colors | TexMeshVertexColorChannel | |||||
VRay Water | TexWater | |||||
Maya | Bulge | TexBulge | Not supported in bump mapping | |||
Checker | TexChecker | Not supported in bump mapping | ||||
Cloth | TexMayaCloth | |||||
File | TexBitmap | |||||
Maya Fluids support | TexMayaFluid TexMayaFluidCombined TexMayaFluidProcedural TexMayaFluidTransformed | |||||
Fractal | TexNoise | Not supported in bump mapping | ||||
Grid | TexGrid | Not supported in bump mapping | ||||
Mandelbrot | ||||||
Mountain | TexMayaMountain | |||||
Movie | ||||||
Noise | TexNoiseMaya | |||||
Ocean | TexNoise | Not supported in bump mapping | ||||
PSD File | ||||||
Ramp | TexRamp | Not supported in bump mapping | ||||
Water | TexNoise | Not supported in bump mapping | ||||
3D Textures | V-Ray | VRay Particle Tex | ParticleTex | |||
Maya | Brownian | TexNoise | Not supported in bump mapping | |||
Cloud | TexNoise | Not supported in bump mapping | ||||
Crater | TexNoise | Not supported in bump mapping | ||||
Granite | TexGranite | Not supported in bump mapping | ||||
Leather | TexMayaLeather | |||||
Mandelbrot 3D | ||||||
Marble | TexMarble | Not supported in bump mapping | ||||
Rock | TexRock | Not supported in bump mapping | ||||
Snow | TexSnow | Not supported in bump mapping | ||||
Solid Fractal | TexNoise | Not supported in bump mapping | ||||
Stucco | TexMayaStucco | |||||
Volume Noise | TexNoiseMaya | |||||
Wood | TexWood | |||||
Env Textures | V-Ray | VRay Plugin Node Tex | ||||
VRay Sky | TexSky | |||||
Maya | Env Ball | |||||
Env Chrome | ||||||
Env Cube | ||||||
Env Sky | ||||||
Env Sphere | ||||||
Other Textures
| V-Ray | VRay Bercon Noise | TexBerconNoise | |||
VRay Ptex | TexPtex | |||||
VRay Triplanar | TexTriPlanar | Not supported in bump mapping | ||||
Maya | Layered Texture | TexLayered | Not supported in bump mapping | |||
Utility Textures | V-Ray | VRay Curvature | TexCurvature | |||
VRay Distance Tex | TexDistance | |||||
VRay Fur Sampler | TexVRayFurSampler | |||||
VRay Hair Sampler | TexHairSampler | |||||
VRay Object Properties | ||||||
VRay Place Env Tex | UVWGenEnvironment | |||||
VRay Switch Transform | TexSwitchTransform | |||||
VRayUVWRandomizer | UVWGenRandomizer | Not supported in bump mapping | ||||
VRay User Color | TexUserColor | |||||
VRay User Integer | TexUserInteger | |||||
VRay User Scalar | TexUserScalar | |||||
VRayMult Projection | TexMultiProjection | |||||
Maya | Blend Colors | TexBlend | Not supported in bump mapping | |||
Blend Two Attributes | ||||||
Bump 2D | ||||||
Bump 3D | ||||||
Choice | ||||||
Chooser | ||||||
Clamp | TexClamp | |||||
Color Profile | ||||||
Condition | TexCondition2 | |||||
Contrast | TexMayaContrast | Not supported in bump mapping | ||||
Curve Info | ||||||
Distance Between | TexDistanceBetween | |||||
Double Switch | TexSwitch | |||||
Four by Four Matrix | ||||||
Frame Cache | ||||||
Gamma Correct | MayaGamma | Not supported in bump mapping | ||||
Height Field | ||||||
HSV to RGB | TexHSVToRGB | Not supported in bump mapping | ||||
Light Info -> sampleDistance | TexDistanceToObject | |||||
Luminance | TexLuminance | Not supported in bump mapping | ||||
Mult Double Linear | ||||||
Mult Matrix | ||||||
Multiply Divide | MayaMultiplyDivide | Not supported in bump mapping | ||||
Particle Sampler & Bifrost | TexParticleSampler | |||||
2D Placement | UVWGenMayaPlace2dTexture | |||||
3D Placement | UVWGenObject UVWGenPlanarWorld | Partial - no support for referenced meshes | Not supported in bump mapping | |||
Plus Minus Average | TexPlusMinusAverage | Not supported in bump mapping | ||||
Projection | UVWGenProjection | |||||
Quad Switch | TexSwitch | |||||
Remap Color | TexRemap | Not supported in bump mapping | ||||
Remap HSV | TexRemap | Not supported in bump mapping | ||||
Remap Value | TexRemap | Not supported in bump mapping | ||||
Reverse | TexInvert | Not supported in bump mapping | ||||
RGB to HSV | TexRGBToHSV | Not supported in bump mapping | ||||
Sampler Info | TexVectorOp | Not supported in bump mapping | ||||
Set Range | TexSetRange | Not supported in bump mapping | ||||
Single Switch | TexSwitchFloa | |||||
Stencil | TexStencil | |||||
Surface Info | ||||||
Surf. Luminance | TexSurfaceLuminance | |||||
Triple Switch | TexSwitch | |||||
Unit Conversion | TexMayaConversion | Not supported in bump mapping | ||||
UV Chooser | TexSwitchInt | |||||
Vector Product | TexVectorProduct | Not supported in bump mapping | ||||
Weighted Add Matrix |
Footnotes
1 – Opacity is rendered the same way a clipper is rendered - it is either transparent or opaque. Mid-opacity is not supported.
