This page provides information about the V-Ray Decal in Maya.
VRayDecal provides an easy way to project one material on top of another regardless of the target UV set. The projected material is placed in an adjustable VRayDecal gizmo that controls its size, placement and projection limits in the Viewport.
Multiple VRayDecals can be stacked on top of each other and their overlapping is controlled by the parameters in each VRayDecal object or by their positions in the scene.
The VRayDecal’s effect is visible at render time only.
The material is projected only on the surfaces within the gizmo.
Enabled – Enables the use of VRayDecal. See the example below on one of many decal applications.
Width – Specifies the width of the VRayDecal gizmo in centimeters.
Length – Specifies the length of the VRayDecal gizmo in centimeters.
Height – Specifies the height of the VRayDecal gizmo in centimeters.
Normal Angle – Specifies the angle to which the decal is applied onto the surface below.
Fade Out – Enables the use of a fade out angle to position the decal.
Fade Out Angle – Specifies the angle where the decal effect fades out. The Normal and Fade Out angles determine the start and end points of the decal effect onto the surface. Note that the Fade Out Angle should not be smaller than the Normal Angle. See the Fade Out Angle Example below for more information.
Order – Specifies a layering order when multiple VRayDecal gizmos are present. The decal with the larger Order value is set on top of the other ones. In case of equal Order values, the bounding boxes of the decals are taken into account for positioning.
Enable Mask – When enabled the Mask parameter is activated.
Mask – Masks the projected material based on a texture.
Project on Back Side – When enabled, VRayDecal is also projected on the back side of the object.
As Inclusive List – When enabled, the Exclude List is read as an Inclusive List instead. Rather than not affecting the specified objects, VRayDecal affects only them in the scene.
Exclude List – Specifies a list of objects that are not affected by the VRayDecal.
Example: Decal
The example shows the decal effect applied onto a motorcycle.
Example: Fade Out Angle
The Normal Angle is set to 40 degrees. The first image shows the decal effect without a Fade Out Angle. The second render has a Fade Out Angle set to 120 degrees. Note how the effect is closed between the Normal and Fade Out angles.
- V-Ray GPU supports VRayDecal with a maximum limit of 4 stacked decals, when using masks or when the translucency is lesser than 1.
