This page provides information on the command line interface of the Standalone Simulator tool.
The Standalone Simulator command-line tool allows you to simulate Phoenix simscene files.
Default Paths:
- Windows: C:\Program Files\Chaos Group\Phoenix FD\Maya 20xx for x64\bin\phoenixfd.exe
- Linux: /usr/ChaosGroup/Phoenix FD/Maya 20xx-x64/bin/phoenixfd.bin
- MacOS: /Applications/ChaosGroup/PhoenixFD/Maya20xx/ChaosPhoenix.app/Contents/MacOS/phoenixfd.bin
Currently the Standalone simulator supports only Phoenix Simulator and Source nodes, as well as Phoenix Node properties.
Still to be added are: textures, support for animated options, animated geometries, time-bend resimulation.
Mandatory Arguments
Note that arguments are preceded by "-" and followed by "=" if they require a value. All arguments and values are case insensitive.
-sceneFile= – Specifies the scene file that will be simulated. Paths must be absolute. If blank spaces are included the path must be wrapped in apostrophes.
Optional Arguments
-numThreads= – The number of simulation threads that will be used. The default is 0 - use all available threads.
-restoreFromFrame= – Continues a simulation from the specified frame, or the latest Backup frame containing the full simulation state up to the current specified frame, which is controlledby the Backup Interval parameter in the Output rollout. This way, a Phoenix simulation that has been stopped previously can be resumed from the point you left off, even after the software has been closed and reopened.
-verboseLevel= – Specifies how much info is printed in the terminal and the Phoenix log.
0 - Only errors are printed.
1 - Errors and warnings are printed.
2 - Errors, warnings and important info are printed.
3 - Errors, warnings and more detailed information.
4 - Errors, warnings and extremely detailed information that could slow down the simulation.
-help – Prints help text.
-credits – Prints copyright notices for the Phoenix Standalone Simulator and used libraries.
