This page provides information about the Dome Light in V-Ray for Grasshopper.
The V-Ray Dome Light node creates a light shining inward at the scene as if from a spherical or hemispherical light source outside the scene extents. This light is frequently used for Image-Based lighting using panoramic HDR images as environments.
Input Parameters
On (Boolean) – Enables or disables the light source.
Invisible (Boolean) – Controls the light source visibility. Does not affect its illuminance.
Texture (AColorTex) – Specifies the color or the texture of the light. A high dynamic range texture can be used.
Intensity (Number) – Light source intensity. Calculated in Default (Scalar) units.
Shape (Integer) – Controls whether the Dome light covers the entire scene or only the half above the horizon line.
Base Plane (Plane) – Controls the orientation of the dome light defining the equatorial plane of the imaginary shape encompassing the entire model. The texture mapping will match this plane as well. The X and Z axes the texture UV coordinate system.
Output Parameters
Add Light (Generic Data) – Light output that can be connected to a Renderer.
