This page provides information about the Material Select Render Element in V-Ray for Cinema 4D.
This render element isolates and renders only objects in the scene to which the material selected is applied. All objects in the scene to which the material has been applied will render normally with proper lighting, reflections and refractions, and all other objects will simply render black.
Similar to the Light Select Render Element, the Material Select Render Element enables isolation of objects with a particular material in the composite.
While you may only have one material at a time specified in a single Material Select element, you may have as many Render Select elements as needed in your scene.
UI Path: ||V-Ray|| > Render Elements > Material Select
How to add a render element to a scene
Properties
Enable Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post render color adjustments made from the VFB.
