© Taichi Kobayashi
« Previous Version 10 Next »
This page provides information on the V-Ray UVWGenMayaPlace2dTexture node.
The V-Ray UVWGenMayaPlace2dTexture node allows you to use Named Channel mapping within the Mat Network.
UI path: ||mat Network|| > V-Ray > Texture: Mapping > V-Ray UV Channel Name
UV Name – Specifies the name of the UV channel that should be used.
Repeat U / V – Specifies the number of times to repeat the texture in the U / V direction.
Coverage U / V – Specifies the U / V coverage amount.
Translate Frame U / V – Specifies a U / V texture translate frame amount.
Rotate Frame – Specifies a rotation amount for the texture.
Rotate UV – Specifies a rotation amount in UV space.
Offset U / V – Specifies an offset for the U / V position.
Noise U / V – Specifies the amount of noise to add.
Mirror U / V – Enables texture mirroring in the U / V direction.
Wrap U / V – Enables texture wrapping in the U / V direction.
Stagger – Enables texture staggering.
