© Taichi Kobayashi
Version 1 Next »
This page contains information about the V-Ray TexBezierCurveColor node.
The V-Ray Bezier Curve node outputs the 2D piecewise cubic Bezier curve float result (Y axis) from the given input float argument (X axis).
UI Path: ||mat Network|| > V-Ray> Texture: Utility > V-Ray Bezier Curve Color
User Curve R – Enables the use of red curve.
Use Curve G – Enables the use of green curve.
Use Curve B – Enables the use of blue curve.
Num Bezier Points for R/G/B Curve – Specifies the number of precisely calculated points from Bezier curves.
Extrapolate Beyond End Points for R/G/B Curve – When enabled, extrapolates beyond the control points.
Extrapolate Type for R/G/B Curve – Specifies the type of extrapolation for points out of the control range.
