In this chapter we'll cover slightly more complex light source in V-Ray - the dome light. It represents a light emitting dome encompassing the scene at infinity. It's usually used for HDR image based lighting (IBL) with a spherical texture file.
Along with the common ones for the lights, the LightDome plugin has some specific parameters:
- dome_spherical - Set to true to extend the dome to a full sphere. By default it is only a half-dome centered at the scene zenith. SettingsUnitsInfo::scene_upDir needs to be properly set.
- dome_tex - A texture plugin to use. Note that this usually requires spherical mapping.
- use_dome_tex - You also have to set this to true to use the dome_tex.
- tex_resolution - The texture is actually resampled at this resolution. The default is 512, so even if you have a high resolution image, it may look pixelated if you don't increase this. This will consume more memory.
- dome_targetRadius - Defines a sphere around the light icon where photons are being shot when photon-mapped caustics or the global photon map are used.
- dome_emitRadius - Defines a sphere around the light icon from which photons are being shot towards the target radius area.
- tex_adaptive - The adaptivity of the sampling to the texture brightness (0.0 - no adaptivity; 1.0 - full adaptivity).
- dome_rayDistance - Allows you to specify the maximum distance to which shadow rays are going to be traced.
- dome_rayDistanceMode - Specifies the method of determining the maximum distance to which shadow rays are going to be traced. Could be 0: None, 1: From GI Settings (the Ray Dist value is determined by the ray distance parameter in the GI settings) and 2: Explicit (the ray distance value is determined by the dome_rayDistance parameter).
- affect_alpha - When this option is enabled, the virtual sphere on which the dome texture is mapped is going to be visible as a solid object in the alpha.
Example
Here we'll show how to add a LightDome to a scene.
# Compatibility with Python 2.7. from __future__ import print_function # The directory containing the vray shared object should be present in the PYTHONPATH environment variable. # Try to import the vray module from VRAY_SDK/python, if it is not in PYTHONPATH import sys, os VRAY_SDK = os.environ.get('VRAY_SDK') if VRAY_SDK: sys.path.append(os.path.join(VRAY_SDK, 'python')) import vray SCENE_PATH = os.path.join(os.environ.get('VRAY_SDK'), 'scenes') # Change process working directory to SCENE_PATH in order to be able to load relative scene resources. os.chdir(SCENE_PATH) # The renderer is automatically closed after the `with` block. with vray.VRayRenderer() as renderer: # Register a simple log callback. Always useful for debugging. def dumpMsg(renderer, message, level, instant): if level == vray.LOGLEVEL_ERROR: print("[ERROR]", message) elif level == vray.LOGLEVEL_WARNING: print("[Warning]", message) elif level == vray.LOGLEVEL_INFO: print("[info]", message) # Uncomment for testing, but you might want to ignore these in real code #else: print("[debug]", message) renderer.setOnLogMessage(dumpMsg) # Load scene from a file. renderer.load(os.path.join(SCENE_PATH, 'lighting.vrscene')) # Remove original light source from the scene. del renderer.plugins["VRayLightDomeShape1"] # The UVWGenEnvironment allows spherical, cube, etc. textures to be # mapped on the environment color slot or dome lights. uvwgen = renderer.classes.UVWGenEnvironment() # Specify the type and shape of the texture. # Possible values are: # angular # cubic # mirror_ball # spherical - default # screen # max_spherical # spherical_vray # max_cylindrical # max_shrink_wrap uvwgen.mapping_type = 'spherical' # Specify transformation of the input directions. uvwgen.uvw_matrix = vray.Matrix( vray.Vector(1, 0, 0), vray.Vector(0, 0, 1), vray.Vector(0, -1, 0)) uvwgen.ground_on = 1 bitmap = renderer.classes.BitmapBuffer() # unlike JPG files, HDR files are linear bitmap.transfer_function = 0 bitmap.file = os.path.join(SCENE_PATH, 'assets', 'Sea_D.hdr') texture = renderer.classes.TexBitmap() # Specify UVW generator for the texture. texture.uvwgen = uvwgen # Specify the bitmap that the texture will be using. texture.bitmap = bitmap # LightDome is a light source plugin that can be used to create lights that # shine inward at the scene as if from a spherical or hemispherical light source outside the scene extents. # This light is frequently used for image-based lighting using panoramic HDR images used as environments. light = renderer.classes.LightDome() # Specify the light position, rotation and scale. light.transform = vray.Transform( vray.Matrix( vray.Vector(0, 0, 1), vray.Vector(1, 0, 0), vray.Vector(0, 1, 0)), vray.Vector(0, 0, 0)) # Switches between a hemispherical or (full) spherical shape of the light. # Possible values are: # True (Sphere) # False (Hemisphere) light.dome_spherical = True # Specify the light intensity based on the 'units' parameter. light.intensity = 4 # Specify the light texture. light.dome_tex = texture # Enable the use of a light texture. # If "use_dome_tex = False" the 'color' of the light will be used instead. light.use_dome_tex = True # Specify shadow offset from the surface. Helps to prevent polygonal shadow artifacts on low-poly surfaces. light.shadowBias = 0.02 # Specify that the bumped normal should be used to check if the light direction is below the surface. light.bumped_below_surface_check = True # Start rendering. renderer.startSync() # Wait for rendering to end. renderer.waitForRenderEnd()
#define VRAY_RUNTIME_LOAD_PRIMARY #include "vraysdk.hpp" #include "vrayplugins.hpp" #include "utils.h" using namespace VRay; using namespace VRay::Plugins; using namespace std; const char *BASE_PATH = getenv("VRAY_SDK"); string SCENE_PATH = (BASE_PATH ? string(BASE_PATH) : string(".")) + PATH_DELIMITER + "scenes"; int main() { // Change process working directory to SCENE_PATH in order to be able to load relative scene resources. changeCurrentDir(SCENE_PATH.c_str()); // Load V-Ray SDK library. VRayInit init(NULL, true); // Create an instance of VRayRenderer with default options. The renderer is automatically closed at the end of the current scope. VRayRenderer renderer; // It's recommended to always have a console log renderer.setOnLogMessage(logMessage); // Load scene from a file. renderer.load("lighting.vrscene"); // Remove original light source from the scene. renderer.deletePlugin("VRayLightDomeShape1"); // The UVWGenEnvironment allows spherical, cube, etc.textures to be mapped on the environment color slot or dome lights. UVWGenEnvironment uvwgen = renderer.newPlugin<UVWGenEnvironment>(); // Specify the type and shape of the texture. // Possible values are: // angular // cubic // mirror_ball // spherical - default // screen // max_spherical // spherical_vray // max_cylindrical // max_shrink_wrap uvwgen.set_mapping_type("spherical"); // Specify transformation of the input directions. uvwgen.set_uvw_matrix( Matrix( Vector(1.0, 0.0, 0.0), Vector(0.0, 0.0, 1.0), Vector(0.0, -1.0, 0.0))); uvwgen.set_ground_on(1); BitmapBuffer bitmap = renderer.newPlugin<BitmapBuffer>(); // unlike JPG files, HDR files are linear bitmap.set_transfer_function(0); bitmap.set_file("assets/Sea_D.hdr"); TexBitmap texture = renderer.newPlugin<TexBitmap>(); // Specify UVW generator for the texture. texture.set_uvwgen(uvwgen); // Specify the bitmap that the texture will be using. texture.set_bitmap(bitmap); // LightDome is a light source plugin that can be used to create lights that // shine inward at the scene as if from a spherical or hemispherical light source outside the scene extents. // This light is frequently used for image-based lighting using panoramic HDR images used as environments. LightDome light = renderer.newPlugin<LightDome>(); // Specify the light position, rotation and scale. light.set_transform(Transform( Matrix( Vector(0.0, 0.0, 1.0), Vector(1.0, 0.0, 0.0), Vector(0.0, 1.0, 0.0)), Vector(0.0, 0.0, 0.0))); // Switches between a hemispherical or (full) spherical shape of the light. // Possible values are: // true (Sphere) // false (Hemisphere) - default light.set_dome_spherical(true); // Specify the light intensity based on the 'units' parameter. light.set_intensity(4); // Specify the light texture. light.set_dome_tex(texture); // Enable the use of a light texture. // If "use_dome_tex = false" the 'color' of the light will be used instead. light.set_use_dome_tex(true); // Specify shadow offset from the surface. Helps to prevent polygonal shadow artifacts on low-poly surfaces. light.set_shadowBias(0.02f); // Specify that the bumped normal should be used to check if the light direction is below the surface. light.set_bumped_below_surface_check(true); // Start rendering. renderer.startSync(); // Wait for rendering to end. renderer.waitForRenderEnd(); return 0; }
using System; using System.IO; using VRay; using VRay.Plugins; namespace _04_dome { class Program { static void Main(string[] args) { string SCENE_PATH = Path.Combine(Environment.GetEnvironmentVariable("VRAY_SDK"), "scenes"); // Change process working directory to SCENE_PATH in order to be able to load relative scene resources. Directory.SetCurrentDirectory(SCENE_PATH); // Create an instance of VRayRenderer with default options. The renderer is automatically closed after the `using` block. using (VRayRenderer renderer = new VRayRenderer()) { // Add a listener for any type of log message. renderer.LogMessage += new EventHandler<MessageEventArgs>((source, e) => { // You can remove the if for testing, but you might want to ignore Debug in real code if (e.LogLevel != LogLevelType.Debug) { Console.WriteLine(String.Format("[{0}] {1}", e.LogLevel.ToString(), e.Message)); } }); // Load scene from a file. renderer.Load("lighting.vrscene"); // Remove original light source from the scene. renderer.DeletePlugin("VRayLightDomeShape1"); // The UVWGenEnvironment allows spherical, cube, etc. textures to be mapped on the environment color slot or dome lights. UVWGenEnvironment uvwgen = renderer.NewPlugin<UVWGenEnvironment>(); // Specify the type and shape of the texture. // Possible values are: // angular // cubic // mirror_ball // spherical - default // screen // max_spherical // spherical_vray // max_cylindrical // max_shrink_wrap uvwgen.MappingType = "spherical"; // Specify transformation of the input directions. uvwgen.UvwMatrix = new Matrix( new Vector(1, 0, 0), new Vector(0, 0, 1), new Vector(0, -1, 0)); uvwgen.GroundOn = 1; BitmapBuffer bitmap = renderer.NewPlugin<BitmapBuffer>(); // unlike JPG files, HDR files are linear bitmap.TransferFunction = 0; bitmap.File = Path.Combine("assets", "Sea_D.hdr"); TexBitmap texture = renderer.NewPlugin<TexBitmap>(); // Specify UVW generator for the texture. texture.Uvwgen = uvwgen; // Specify the bitmap that the texture will be using. texture.Bitmap = bitmap; // LightDome is a light source plugin that can be used to create lights that // shine inward at the scene as if from a spherical or hemispherical light source outside the scene extents. // This light is frequently used for image-based lighting using panoramic HDR images used as environments. LightDome light = renderer.NewPlugin<LightDome>(); // Specify the light position, rotation and scale. light.Transform = new Transform( new Matrix( new Vector(0, 0, 1), new Vector(1, 0, 0), new Vector(0, 1, 0)), new Vector(0, 0, 0)); // Switches between a hemispherical or (full) spherical shape of the light. // Possible values are: // true (Sphere) // false (Hemisphere) light.DomeSpherical = true; // Specify the light intensity based on the 'units' parameter. light.Intensity = 4; // Specify the light texture. light.DomeTex = texture; // Enable the use of a light texture. // If "use_dome_tex = False" the 'color' of the light will be used instead. light.UseDomeTex = true; // Specify shadow offset from the surface. Helps to prevent polygonal shadow artifacts on low-poly surfaces. light.ShadowBias = 0.02F; // Specify that the bumped normal should be used to check if the light direction is below the surface. light.BumpedBelowSurfaceCheck = true; // Specify the number of parameter samples for motion blur. light.Nsamples = 1; // Start rendering. renderer.StartSync(); // Wait for rendering to end. renderer.WaitForRenderEnd(); } } } }
var path = require('path'); var vray = require(path.join(process.env.VRAY_SDK, 'node', 'vray')); var SCENE_PATH = path.join(process.env.VRAY_SDK, 'scenes'); // Change process working directory to SCENE_PATH in order to be able to load relative scene resources. process.chdir(SCENE_PATH); // Create an instance of VRayRenderer with default options. var renderer = vray.VRayRenderer(); // It's recommended to always have a console log callback renderer.on("logMessage", function(message, level, instant) { if (level == vray.LOGLEVEL_ERROR) console.log("[ERROR] ", message); else if (level == vray.LOGLEVEL_WARNING) console.log("[Warning] ", message); else if (level == vray.LOGLEVEL_INFO) console.log("[info] ", message); // Uncomment for testing, but you might want to ignore these in real code //else console.log("[debug] ", message); }); // Load scene from a file asynchronously. renderer.load("lighting.vrscene", function(err) { if (err) throw err; // Remove original light source from the scene. delete renderer.plugins["VRayLightDomeShape1"]; // The UVWGenEnvironment allows spherical, cube, etc. textures to be mapped on the environment color slot or dome lights. var uvwgen = renderer.classes.UVWGenEnvironment(); // Specify transformation of the input directions. uvwgen.uvw_matrix = vray.Matrix( vray.Vector(1, 0, 0), vray.Vector(0, 0, 1), vray.Vector(0, -1, 0)); uvwgen.ground_on = 1; // Specify the type and shape of the texture. // Possible values are: // angular // cubic // mirror_ball // spherical - default // screen // max_spherical // spherical_vray // max_cylindrical // max_shrink_wrap uvwgen.mapping_type = "spherical"; var bitmap = renderer.classes.BitmapBuffer(); // unlike JPG files, HDR files are linear bitmap.transfer_function = 0; bitmap.file = path.join(SCENE_PATH, "assets", "Sea_D.hdr"); var texture = renderer.classes.TexBitmap(); // Specify UVW generator for the texture. texture.uvwgen = uvwgen; // Specify the bitmap that the texture will be using. texture.bitmap = bitmap; // LightDome is a light source plugin that can be used to create lights that // shine inward at the scene as if from a spherical or hemispherical light source outside the scene extents. // This light is frequently used for image-based lighting using panoramic HDR images used as environments. var light = renderer.classes.LightDome(); // Specify the light position, rotation and scale. light.transform = vray.Transform( vray.Matrix( vray.Vector(0, 0, 1), vray.Vector(1, 0, 0), vray.Vector(0, 1, 0)), vray.Vector(0, 0, 0)); // Switches between a hemispherical or (full) spherical shape of the light. // Possible values are: // true (Sphere) // false (Hemisphere) light.dome_spherical = true; // Specify the light intensity based on the 'units' parameter. light.intensity = 4; // Specify the light texture. light.dome_tex = texture; // Enable the use of a light texture. // If "use_dome_tex = false" the 'color' of the light will be used instead. light.use_dome_tex = true; // Specify shadow offset from the surface. Helps to prevent polygonal shadow artifacts on low-poly surfaces. light.shadowBias = 0.02; // Specify that the bumped normal should be used to check if the light direction is below the surface. light.bumped_below_surface_check = true; // Start rendering. renderer.start(function(err) { if (err) throw err; // Wait for rendering to end. renderer.waitForRenderEnd(function() { renderer.close(); }); }); });
Result
The scene used for this render is called "Lighting_Dome.vrscene" and can be found in the scene bundle (comments to the different parameters available inside).
To test this locally, you'll need to change the absolute path to the dome texture (located in the included scene: "vrscenes/light_dome.vrscene").
