« Previous Version 19 Next »
This page provides information on Corona Bitmap.
When using Corona Renderer, bitmaps can be loaded using two supported nodes in the material editor:
  1. Corona Bitmap
  2. 3ds Max native Bitmap node
Both of them will produce almost identical results, however there are some advantages of using the Corona Bitmap over 3ds Max Bitmap node.
Corona Bitmap
Use Real-World Scale When turned on, applies the map to objects using the real-world Width and Height values instead of UV values.
Map Channel – Allows to specify a map channel.
Offset (U) – Controls a horizontal offset.
Tiling (V) Controls a vertical offset.
Tiling Mode:
No Tiling For UV coordinates outside of [0,1] range the bitmap returns black color.
Repeat Tiling The bitmap is periodically repeated outside of [0,1] range (i.e. for UV coordinates u = 0, v = 1.2 it will have the same value as u = 0, v = 0.2).
Mirrored Tiling The bitmap is periodically repeated, but each odd repetition is mirrored (i.e. for UV coordinates u = 0, v = 1.2 it will have the same value as u = 0, v = 0.8). This means the repetition is seamless.
Clamp For UV coordinates outside of [0,1] range the bitmap has the value of the closest valid pixel in the range (i.e. for UV coordinates u = 0, v = 5 it will have value of u = 0, v = 1). Often called "clamping".
W Rotation [deg] – Rotates the map in Z axis.
Environment mapping
Mode:
Spherical Most common format of environment bitmaps, bitmap pixel coordinates correspond to spherical coordinates.
Screen Tries to map bitmap in such a way that it is mapped parallel to the camera sensor.
Dome Similar to spherical, but the sphere is not infinite, it has a given center and size.
Cross Common format from computer games - bitmap stores environment as unfolded cube.
Mirror Ball Mapping computed from rays reflecting from perfect mirror sphere (quite uncommon, but it was requested by the users).
Rotation [deg] – Rotates the map in X axis.
Transform from object – If used, the bitmap rotation in the environment slot (and dome origin, if dome mapping is used) is controlled by transform from a selected scene object. The other bitmap rotations are still applied on top of this.
Rotation in any axis can be used, so this can be used to tilt maps.
Dome Mode
Origin X/Y/Z – Sets the centerpoint of the virtual dome in the scene, using the units specified in 3ds Max.
Radius  Sets the size of the virtual dome, using the units specified in 3ds Max. The value should be at least a bit larger than the scene size, or unexpected results may occur. A good practice is to use a value similar to the scale of the environment in the image.
Camera height  Controls how much of the image is on the "floor" of the virtual dome, and how much is on the dome itself. If you know the height of the camera when the image was taken, use that value. If you do not know the height of the camera, adjust this by eye to minimize distortion on the floor of the dome.
Crop/Place
OnMakes crop/place active.
Crop – Makes Crop active.
Place – Makes Place active.
View Image – Opens a window that shows the bitmap surrounded by a region outline with handles at its sides and corners
U/V – Crops/Places the bitmap by UV coordinates.
Width/Height – Crops/Places the bitmap by width/height values.
Channel Outputs
AlphaWhen map is used together with constant color, alpha determines how they are mixed (alpha = 1 - only map is used, alpha = 0 only color is used.). Here the user can select how is the alpha computed:
None (Opaque)Alpha is always 1.
RGB IntensityAlpha is computed from RGB color.
Image AlphaAlpha is taken from image (if present, e.g. in TGA/PNG) or set to 1 if missing.
Mono When the output of map is supposed to be a single channel (e.g. for material roughness), this is how we compute it.
RGB IntensityComputed from RGB color.
Image AlphaSingle channel is taken from image (if present, e.g. in TGA/PNG) or set to 1 if missing.
RGBActual color output when map is used for color inputs (e.g. diffuse color in material).
RGBActual color stored in bitmap.
ImageAlphaasgrayGray color is computed from alpha stored in the image.
Bitmap
Load MapSelects the bitmap using the standard file browser.
ReloadReloads the bitmap file using the same name and path. You don’t need to use the file browser to reload the bitmap after you've updated it in your paint program. Clicking reload for any instance of the map updates the map in all sample slots and in the scene.
Filtering
Blur – Controls the blurriness of the image.
InterpolationDetermines how we compute a color for a given UV coordinates from the bitmap. The bitmap is discrete - e.g. pixel has constant color, but pixel has an area and UV coordinates tells us we want color from a given point. The color from such a point is computed from surrounding pixels.
Bilinear (faster)Finds four closest pixels to the UV coordinate and mix their color depending on how close they are to the UV coordinate.
Bicubic (smoother)Similar to bilinear, but includes even more pixels in the color computation.
Nearest Neighbour (low quality, faster) It just finds pixel closest to the UV coordinate and returns the color.
Examples
Corona Bitmap - Blurring
Blurring - 0.01
Blurring - 1
Blurring - 5
Blurring - 10
Corona Bitmap - Tiling
Tiling - U:1 V:1
Tiling - U:2 V:2
Tiling - U:5 V:5
Corona Bitmap - HDRI
HDRI - Rotation (deg) - 0
HDRI - Rotation (deg) - 50
HDRI - Rotation (deg) - 150
HDRI - Rotation (deg) - 250
HDRI - Rotation (deg) - 350
U: 0.25, V: 0.25
U: 0.5, V: 0.5
U: 1.0, V: 1.0
U: 2.0, V: 2.0
U: 4.0, V: 4.0
Corona Bitmap - W Rotation
0 degree
10 degrees
20 degrees
45 degrees
75 degrees
90 degrees
Corona Bitmap - Tiling modes
Repeat Tiling
No tiling
Clamp
Environment Mapping
 Spherical Mapping
Rotation [deg]: 0
Rotation [deg]: 10
Rotation [deg]: 20
Rotation [deg]: 30
Rotation [deg]: 40
Rotation [deg]: 50
Rotation [deg]: 60
Rotation [deg]: 70
Rotation [deg]: 80
Rotation [deg]: 90
 Dome Mapping
Radius: 10m
Radius: 15m
Radius: 25m
Radius: 40m
Radius: 100m
