« Previous Version 8 Next »
This page provides information about the Material from File in V-Ray for Grasshopper.
V-Ray Material from File loads a .vrmat file. Click on the field to open a file browser window and select a .vrmat file.
Right-click on the component to open V-Ray Material from File context menu.
Use the options to import your materials or use the material presets from Material Library or Cosmos Materials.
Note that invalid input file paths are auto-resolved as long as the files reside at the same location as the .gh project file
Example: Material from File
Download the GH definition here.
Usage Example
Vertex Color Setup. Note the UVW texture is set to UV channel 2
Matching Grasshopper vertex color data between the Rhino Viewport and the VFB
