Enable Deep Output – Specifies whether to include this render element in deep images. Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible. Affect Matte Objects – Sets whether to include matte objects when generating the render element. Color – Applies a color to this channel. Texmap – Allows a bitmap or a procedural texture to be connected. Filtering – Applies an image filter to this channel. Exclude – Specifies a set of objects to be excluded from the Extra Tex channel. Include – Specifies a set of objects to be included in the Extra Tex channel. Force 32 Bit Output – When enabled, stores the Extra Texture render element as a 32-bit float even when writing a 16-bit raw image. This option applies only to multichannel .exr files. Force Lossless Compression – When enabled, lossy DWAA/DWAB compression is not applied to the Extra Tex data stored in a multichannel exr. This option applies only to multichannel .exr files. Denoise – Enables the render element's denoising, provided the Denoiser render element is present. |
