This page provides information about the V-Ray Object Select Render Element in V-Ray for Houdini.
The Object Select Render Element stores only the object(s) called out with a specific Object or Material ID.
This effect is reversible to create a render element that excludes a particular object or objects according to Object or Material ID.
When rendering this element out, it also includes a filter and alpha passes separately to help make it easier to use when compositing.
UI path: ||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > V-Ray Object Select (RE)
Name The text added to the end of the rendered file, when saved as a separate file.
More Than One – When enabled, more than one object is exported.
Object/Material ID – List of selected IDs included in this render pass.
Use Material IDs – When enabled, the pass considers the Material ID and renders accordingly. When disabled, these values are considered to be the Object ID.
Invert Selection – Use the opposite of the selected objects in the render pass.
Affect Matte Objects – Specifies whether to include matte objects when generating the render element. A matte object is an object that has been assigned a Wrapper Material.
Denoise – Enables the render element's denoising, provided the V-Ray Denoiser render element is present.
Color Mapping – When enabled, the Color Mapping options in the render settings are applied to the current render channel.
Deep Output – Specifies whether to include this render element in deep images.
Common Uses
The Object Select render element allows items to be isolated for easier control at a composite level. In the example shown below, the curtains are color corrected and tinted yellow.
V-Ray Object Select
Original Beauty composite
V-Ray Object Select edited
Resulting Beauty composite
  • Object Select Render Element does not support Volumetric effects. For Volumetric effects supported render elements, visit the V-Ray Render Elements Support page.
