Enabled – Turns the light on and off. Color Mode – Determines how the color of the light is controlled, either Color or Temperature. Color – Controls the color of the light. When using photometric units, this color is normalized so that only the color hue is used, whereas the Power parameter determines the light intensity. Temperature – When the Color Mode is set to Temperature, this parameter controls the color of the light by degrees Kelvin. IES File – Load an .ies file to use for the current light. Filter Color – A multiplier for the Color parameter of the light. This option is not available with V-Ray GPU. Power – Determines the intensity of the light. The default value of 0 means the light intensity comes only from the .ies profile. If a value different than 0 is used, that number is taken as the light intensity instead. A reasonable number would be in the range of 500-1000. The value is in lumens. Override Prescribed Power – Overrides the power specified in the file if > 0. The value is in lumens. Rescale Max Intensity – The IES file's default global light intensity is multiplied to match the user's defined light intensity. New Max Intensity – Specifies the strength of the light as a multiplier when Rescale Max Intensity is enabled. |
