This page provides information about the Toon Lighting render element.
The Toon Lighting Render Element stores direct lighting information from lights in the scene that hit the Toon Material and Toon Material Node. This render element can be used to brighten, lessen, or tint the direct lighting in a composite without affecting indirect light or reflections, for example.
The Toon Lighting RE is included in the Lighting RE. It can be subtracted from the main back-to-beauty composite, graded, and added back in.
How to add a render element to a scene.
Properties
Enable Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible.
Filtering – Applies an image filter to this channel.
