The Vantage Live Link settings dialog, available by clicking the Chaos Vantage Live Link settings button, allows you to specify port, frame timeout, as well as object render state. IP Address – Shows the IP address that the Live Link connection connects to. Port – Specifies the port at which the Live Link connection is started. Frame timeout – Sets а specified time in seconds between frames to ensure data transfer for the next frame has begun. Enable Object Render State – When enabled, uses Render states/counts/iterations/modes instead of their viewport representation. Anima 4D assets require this option to be enabled to be rendered properly. Enabling this option саn affect the interactivity of Live Link updates. The Chaos Vantage Live Link settings tool is available with V-Ray 6 for 3ds Max, update 2 and later when using Chaos Vantage 2.2 and later. |
Always make sure you are using the same port in both 3ds Max and Chaos Vantage! |
