When loading a scene in Chaos Vantage, the default camera stored in the .vrscene file is used. Navigating through the scene, you can save many camera views and go back to them when needed. Starting with Chaos Vantage 2.5, if you have numerous cameras, you can filter and sort them through the respective options in the Camera lister. |
Create a cameraTo create a new camera, click the Create camera from current view and current settings ( ) button in the Camera lister. A new camera slot is created from the current view and current camera settings. You can rename the camera slot by double-clicking the camera slot name. You can always go back to the camera that comes from the .vrscene file by selecting the [Home] camera slot. Update camera propertiesTo update the camera properties, tweak the properties you need and then click the Update camera ( ) button of the respective camera slot. For more information on the individual camera properties, see the Camera Tab page. Delete a cameraTo delete a camera, double-click the Delete ( ) button of the respective camera slot. |
