This page guides users who are connecting remotely to a Premium Chaos License or a Chaos Enscape 4.1 Floating license.
Premium and Floating Licenses can be shared between multiple users and devices, or they can be used locally - similar to the Solo and Fixed Licenses.
When doing a shared setup for a Premium/Floating license, the license holder needs to install the license locally on at least one machine in the network. Installing the license happens automatically when you perform a default Chaos product installation. If you only need to install the License Server application separately, see the Installation page. This machine can use the license, but it also serves as a connection point for others to connect to the license.
Using a Premium/Floating license locally requires installing your Chaos product with the "Local License" setting in the installer and logging in with your Chaos account credentials when prompted.
Keep in mind that a single license can be used by a single user at a time. You need to add more licenses if you wish multiple users to work at the same time.
To create a setup for sharing Premium/Floating licenses, please see the Admin Workflow page. |
Corona Activation Enscape Activation When connecting remotely to a Floating License for Enscape 4.1, follow the step-by-step guide specifically for Enscape in the Enscape First Steps article. If you are using Enscape 4.0 or older, see the Enscape License Activation article. |
If you are activating an Enscape Floating license, see the How to set up Floating Licenses in Enscape 4.1 and onwards article for a more detailed guide. |
