The Object selector node allows you to select one object from the scene and import it into the V-Ray Node Editor. This node has no editable parameters. In the image, an Object Selector is used to connect a Cube geometry from the scene to a Mesh Light, as its Geometry. Objects also need to be selected for some Effects.
UI Path: ||V-Ray Node Editor|| > Shader > Add > Selectors > V-Ray Object Selector UI Path: ||V-Ray Node Editor|| > Object > Add > Selectors > V-Ray Object Selector UI Path: ||V-Ray Node Editor|| > World > Add > Selectors > V-Ray Object Selector |
