Channel Name – Customizable name for the render channel. Enable Deep Output – Specifies whether to include this render channel in deep images. Color Mapping – Applies the color mapping options specified in the Color Mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default. Consider For Anti-Aliasing – When enabled, anti-aliasing is used where possible. Filtering – Applies an image filter to this channel. Vfb Color Corrections – Applies the post-render color adjustments made from the VFB. Denoise – Enables the render channel's denoising, provided the Denoiser is enabled. |
