This page provides information about the Toon Specular Render Channel in V-Ray for Blender.
The Toon Specular Render Channel is an image that stores Toon Specular reflection (highlights) information calculated from the Toon Material.
The brighter the area, the more Toon highlight reflection the object exhibits in the render. Toon Specular highlights are colored if the Reflection Color parameter of a material is colored.
The Toon Specular Render Channel is included in the Specular Render Channel. It can be subtracted from the main back-to-beauty composite, graded, and added back in.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Advanced > V-Ray Toon Specular
Properties
Enable Deep Output  Specifies whether to include this render channel in deep images.
Color Mapping
Denoise – Enables the render channel's denoising, provided the Denoiser is enabled.
