This page provides information about the Matte Shadow Render Channel in V-Ray for Blender.
The Matte Shadow Render Channel shows areas where light doesn't reach. Compare this with the Raw Shadow render channel, which stores areas of cast shadows. While technically not part of the Beauty render channels, the Matte Shadow Render Channel can be used to lighten cast shadows by adding it to the Raw Total Light render channel. It can also be used to assist in adding 3D channels to a background image or footage in the composite.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Matte > V-Ray Matte Shadow
Channel Name – Customizable name for the render channel.
Enable Deep Output – Specifies whether to include this render channel in deep images.
Color Mapping –
Consider For Anti-Aliasing – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post-render color adjustments made from the VFB.
