This page provides information about the Raw Refraction Render Channel in V-Ray for Blender.
The Raw Refraction Render Channel is a color image that stores refraction information calculated from materials' refraction values in the scene. Surfaces with no refraction values set in their materials contain no information in the render channel and, therefore, render black.
In comparison, the Refraction Filter render channel is a render channel that indicates varying degrees of refraction in the scene through brightness values in the image. Multiplying these two render channels together produces the Refraction render channel.
Note: To properly calculate the Raw Refraction Render channel, the Refraction render channel must also be added to the list of render channels so that all the refraction information in the scene can be determined.
UI Path: ||V-Ray Node Editor|| > World > Render Channels >Raw > V-Ray Raw Refraction
Properties
Enable Deep Output  Specifies whether to include this render channel in deep images.
Color Mapping –
