This page provides information about the Refraction Filter Render Channel in V-Ray for Blender.
The Refraction Filter Render Channel is an image that stores refraction information calculated from the materials' refraction values in the scene. Materials with no refraction values appear as black, while completely refractive materials appear as white, and everything in between appears as a shade of gray. If any hue (color) is specified in the material's Refractive Color parameter, that hue and value are represented here in the Refraction Filter as well as being affected by the refraction's Amount parameter.
In comparison, the Raw Refraction Render Channel is a color render channel that takes materials and their colors into account when rendering refraction. Multiplying these two render channels together produces the Refraction Render Channel.
Note: To properly calculate the Refraction Filter Render Channel, the Refraction Render Channel must also be added to the list of render channels being calculated during the rendering process to properly determine all the refraction information in the scene.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Advanced > V-Ray  Refraction Filter
Properties
Enable Deep Output  Specifies whether to include this render channel in deep images.
Color Mapping – Applies the color mapping options specified in the Color Mapping rollout of the V-Ray tab in the Render Settings window to this render channel. This option is enabled by default.
