To update a view with a new position, click the Edit Button on the view you would like to update: You should now see a section called Camera. This is where you will have a section for the X, Y, Z , Orientation, Pitch and Yaw. *Pitch = degrees up and down *Yaw is the degree in rotation Once you start moving around in the Enscape window to the new desired position, you will see all these values updated. *If you want to undo this, simply click the undo button and it will revert back to the original position. Once you are happy with the new position of the view, simply click the Save Button at the bottom of the menu and the new changes will be reflected in the Sketchup Scenes Panel view as well. |
