To run V-Ray, you have to:
After installing V-Ray for Blender, load the Add-on in Blender and sign in with your Chaos account when prompted.
Steps
When you open Blender, go to Edit > Preferences. This opens the Blender Preferences window. Go to the Add-ons tab, and search for V-Ray. Make sure to turn off the Enabled Only option.
Enable the V-Ray For Blender plugin.
Continue according to your license setup:
Solo and Cloud-Based Floating Licenses
Network Floating Licenses
If you have a Chaos Solo license plan or are connected to a Cloud-Based Floating License, follow these steps:
Using V-Ray requires an account with an active license. V-Ray for Blender will prompt you to sign in, if needed. Select Sign in from this dialog and enter your Chaos account credentials on the Chaos accounts Sign in webpage.
Read more about the licensing process and functionality in the Chaos Licensing documentation.
Then, from the Render Properties, select V-Ray as the Render Engine.
If you are connecting to a Floating Chaos License, which is set up to be shared within a network, follow these steps.
  • The administrator needs to give you their machine's IP address. This serves as your connection point to the Chaos License.
  • When installing your Chaos product, at the Licensing step, select Remote. In the Primary License Server field, type the server IP address that your license administrator gave you. At the end, add the :30304 port. See the Installation page and follow the steps for your Chaos installation.
  • You are automatically connected to the active licenses after completing the installation.
Example screenshot
