Clicking on the Share button will show the following popup: You can either use the Copy button to copy the URL which can then be pasted into an email or document. Or, you can invite collaborators directly to an email address by adding the recipient’s email address and clicking the Send Invitation button. You can share your images, folders or projects. You can set the person as a Viewer or Editor. The link access can have one of the following access levels: Same as parent – The item inherits the same setting as the folder or project has. Invited only – Only invited people are able to access the item. Anyone can view – Anyone who has the link can view the item. Anyone can comment – Anyone who has the link can view and comment on the item. The Lock comments option can be set to either lock or unlock the comments to collaborators for this item. This will prevent new comments from being added, but the comment section will still be seen. It can also be set to Same as parent, which is the same as the parent folder or project setting. View the full list of user permissions here. |
