Upload to Chaos Cloud – Submits the currently open scene for rendering in Chaos Cloud. Valid Frame Range – Specifies how to obtain the frame range. From ROP – Takes the settings for the render job from the connected V-Ray Renderer node. Current Frame – Renders the current frame only. Frame Range – Renders a specified range of frames. Start/End/Inc – Specifies a Start frame, End frame and Increment frame manually when the Valid Frame Range is set to Frame Range. Override Camera Resolution – When enabled, overrides the camera resolution. Resolution – Specifies a camera resolution for the render job when Override Camera Resolution option is enabled. |
