The Background Render Element stores an image of the texture used in the background behind geometry in a scene, as seen from the camera. Geometry that blocks the background image renders as black. This render element interprets only a background texture, set as Env. Matte Texture (Render Settings > V-Ray > Overrides > Environment). Other types of manually created backgrounds, such as a plane mapped with a texture set outside a window, are not interpreted as a "background" for the purposes of this render element. This render element can be used to enhance or edit only the background of a scene after it has been rendered. See the example.
UI Path: ||V-Ray|| > Render Elements > Background
How to add a render element to a scene  |
