The parameters for this render channel appear in the Parameters tab under the out Network and within the render elements node. Name – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.ExtraTex.vrimg). Texture – An input slot for a texture. Exclude List – Specifies a set of objects to be excluded from the extraTex channel. Exclude List As Inclusive Set – When enabled, V-Ray applies Extra Texture only to objects in the Exclude List. When disabled, V-Ray applies Extra Texture to all objects out of the Exclude List. Denoise – Enables the render element's denoising, provided the V-Ray Denoiser render element is present. Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible. Filtering – Applies the image filter to this channel. Image filter settings are in the AA sub-tab of the Sampler tab of the V-Ray Renderer node. Affect Matte Objects – Sets whether to include matte objects when generating the render channel. A matte object is an object that has been assigned a Wrapper Material or has the Matte surface option of the Object Properties enabled. Force 32-bit Output – When enabled, stores the Extra Texture render element as a 32-bit float even when writing a 16-bit raw image. This option applies only to multichannel .exr files. Force Lossless Compression – When enabled, forces lossless compression for this channel when DWAA/DWAB compression is used. Deep Output – Specifies whether to include this render element in deep images. |
