Color Min – Specifies the minimum output color value for the most concave area (the dents in the mesh). Default value is 0 - completely black. Color Max – Specifies the maximum output color value for the most convex area (the peaks in the mesh). Default value is 1 - white. Gain – Multiplies the output values. Lift – Uniformly lightens the output values. Gamma – Applies gamma correction to the output values. Pivot – Pivots the value to the gamma correction (output values equal to the pivot value are left unchanged). Clamp – When enabled, clamps the Color Min and Color Max values in [0,1] range (negative values are output as 0 and values above 1 are being output as 1). |
