This page introduces the different material types in V-Ray for Houdini.
There are a number of different materials for use with V-Ray for Houdini. These materials are quite versatile and each can be used in a number of ways to achieve different looks as needed from simulating simple surface properties like plastics and metals, to simulating complex uses such as translucent objects, subsurface materials such as skin, and even light emitting objects.
Some basic information on each material can be found below, but for more details, please see the dedicated pages for each one.
Note: While V-Ray will render perfectly using Houdini's own standard materials, these V-Ray specific materials offer a higher level of illumination and surface accuracy, as well as several features not found in standard Houdini versions.
UI Paths
||shop Network|| > Material > V-Ray Material node > V-Ray > Material sub-menu
 ||mat Network|| > V-Ray > Material sub-menu
V-Ray Material Builder Node
The V-Ray Material Builder (vrayMaterialBuilder) node is a container that allows you to create V-Ray materials, textures, and additional V-Ray nodes.
By default, it creates a V-Ray Material (BRDFVRayMtl) connected to a V-Ray Material Output node. For additional information, see the V-Ray Material Builder page.
List of V-Ray BRDF Materials
Blend
Bump Material | BRDFBump
Car Paint Material | BRDFCarPaint
 Flakes Material  | BRDFFlakes
Hair Material | BRDFHair4
 Light Material | BRDFLight
 Hair 3 Material | BRDFHair3
Scanned Material | BRDFScanned
Skin Material | BRDFSkinComplex
SSS 2 Complex Material | BRDFSSS2Complex
alSurface Material | BRDFAlSurface
V-Ray Material | BRDFVRayMtl
List of Additional V-Ray Material Nodes
Two Sided Material | Mtl2Sided
VRmat Material | MtlVRmat
Wrapper Material | MtlWrapper
 Render Stats Material | MtlRenderStats
Override | MtlOverride
Multi ID | MtlMulti
 Material ID | MtlMaterialID
Round Edges | MtlRoundEdges
Single Material | MtlSingleBRDF
