This page provides information on running V-Ray on a machine that does not have it locally installed.
The following instructions apply to 3ds Max 2021 and earlier. Find instruction for 3ds Max 2022 and later at the Running V-Ray Autodesk app packages from Arbitrary Location page.
It is possible to run V-Ray from an arbitrary location, rather than installing it locally.
  1. Run the regular V-Ray installer, but prefix the Program Files folder with some temporary directory for all four paths. This gives you a folder that contains everything that V-Ray puts in both the 3ds Max folders and its own Program Files folders.
  2. Copy that temporary folder to some network location (preferably one that also indicates the V-Ray version and/or build number and the 3ds Max version).
  3. Uninstall V-Ray and remove any files that remain after the uninstallation.
  4. In the temporary folder, create a plugin.ini file with the absolute paths to the V-Ray plugins:
    [Directories]
    VRay=\\server\share\vray_adv_max2021_x64.25566\Program Files\Autodesk\3ds Max 2021\plugins\
    vrayplugins=\\server\share\vray_adv_max2021_x64.25566\Program Files\Autodesk\3ds Max 2021\plugins\vrayplugins\
  5. In the temporary folder, create a .bat file that contains environment variables that are needed by V-Ray and runs 3ds Max with the custom plugin.ini file:
    SET PATH=%~dp0Program Files\Autodesk\3ds Max 2021;%~dp0Program Files\Chaos\V-Ray\3ds Max 2021\bin;%PATH%
    SET VRAY_FOR_3DSMAX2021_MAIN=%~dp0Program Files\Chaos\V-Ray\3ds Max 2021\bin
    SET VRAY_FOR_3DSMAX2021_PLUGINS=%~dp0Program Files\Chaos\V-Ray\3ds Max 2021\bin\plugins
    SET VRAY_MDL_PATH_3DSMAX2021=%~dp0Program Files\Chaos\V-Ray\3ds Max 2021\mdl
    "C:\Program Files\Autodesk\3ds Max 2021\3dsmax.exe" -p %~dp0\plugin.ini
  6. In the temporary folder, create a .bat file that contains environment variables that are needed by V-Ray and runs V-Ray spawner with the custom plugin.ini file:
    vrayspawner2021.exe -AppName="C:\Program Files\Autodesk\3ds Max 2021\3dsmax.exe" -cmdparams="-p %~dp0\plugin.ini"
  7. Use the specified .bat files to run 3ds Max or V-Ray spawner with the specific V-Ray version.
Limitations
This approach works well for render servers where V-Ray is used only for rendering. However, it has a few limitations when 3ds Max is used in interactive mode because some 3ds Max paths cannot be controlled; these limitations can be avoided by expanding the .bat file above to copy some additional files from the network location to the local 3ds Max user folder:
  • MaxScripts provided by V-Ray are not available (V-Ray scene converter, V-Ray Bitmap to VRayBitmap converter, and others). To make MaxScripts available, copy them to the "scripts\startup" folder of 3ds Max.
  • "Realistic" view of V-Ray materials and maps in the Nitrous viewport is not available and attempting to use this mode might lead to crashes. To make the "Realistic" view work, copy the AMG folder from <\\server\share\network_location>\Program Files\Autodesk\3ds Max ####\AMG into the 3ds Max installation C:\Program Files\Autodesk\3ds Max ####\AMG. Note that there is already an AMG folder in the 3ds Max installation. It contains shaders for some Autodesk materials. More information is available here. #### stands for the number of 3ds Max version.
  • The viewport shaders must be copied to the relevant 3ds Max folder ("AMG" for 3ds Max 2017 and later) in C:\Program Files\Autodesk\3ds Max 20##\AMG.
  • Icons for the V-Ray toolbar are missing and some buttons might not work properly. To make the icons appear, copy them to the 3ds Max "UI_In" folders, and copy the V-Ray MaxScripts to the "scripts\startup" folder.
  • The .vrmat editor is not available. To make it work, additional files must be copied to the 3ds Max "python" folder.
  • Viewport IPR is not available. To make it available, copy the V-Ray folder (arbitrary location...\3ds Max 2021\scripts) to the "scripts" folder of 3ds Max.
