This page gives information on the  Raw Lighting Render Element.
The Raw Lighting Render Element stores the effects of direct lighting on scene objects with no diffuse components. It is useful for adjusting the brightness of direct lighting during compositing.
VRayVFB  – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Deep output – Specifies whether to include this render element in deep images.
Color mapping – Applies the color mapping options specified in the Color mapping rollout (Render Setup window > V-Ray tab) to this render element. This option is enabled by default.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise –  Specifies whether to denoise this render element.
Common Uses
The Raw Lighting Render Element is useful for changing the appearance of direct lighting in a compositing or image editing software. In this example, you can see how the image looks before and after post-production.
Underlying Compositing Equation
VRayRawLighting   x VrayDiffuseFilter = VRayLighting
