Name – The text added to the end of the rendered file, when saved as a separate file. More Than One – When enabled, more than one object is exported. Object/Material ID – List of selected IDs included in this render pass. Use Material IDs – When enabled, the pass considers the Material ID and renders accordingly. When disabled, these values are considered to be the Object ID. Invert Selection – Use the opposite of the selected objects in the render pass. Affect Matte Objects – Specifies whether to include matte objects when generating the render element. A matte object is an object that has been assigned a Wrapper Material. Denoise – Enables the render element's denoising, provided the V-Ray Denoiser render element is present. Color Mapping – When enabled, the Color Mapping options in the render settings are applied to the current render channel. Deep Output – Specifies whether to include this render element in deep images. |
