The Direct Lighting Render Element stores direct lighting and diffuse color information.
||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > Color Channel > Type > Direct Lighting
The Direct Lighting Render Element is useful for changing the appearance of direct illumination after rendering in a compositing or image editing application. Below are a couple of examples of possible uses.
Raw Direct Lighting x Diffuse = Lighting
