Default Color – Specifies a default color or texture for objects without Object IDs. Get ID from – Specifies the meaning of the ID parameters. Use face material ID – When more than one material is applied to the different faces of the same object, Maya internally creates face IDs. If all those materials share the same VRayMultiSubTex, V-Ray will considers the face IDs when feeding the data (color or texture) to the materials. Use object ID – The VRayMultiSubTex considers the Object IDs of the object when feeding the data (color or texture) to the material. Random by RenderID – The VRayMultiSubTex assigns random colors based on RenderIDs (internally generated by V-Ray). Random by node name – Generates a color index based on the name of the node that the texture is applied to. Random by instance ID – The VRayMultiSubTex assigns random colors based on the IDs of objects instanced with the particle instancer in Maya. Texture Switch – Enables the Switch texture parameter to determine which texture is used in the material. Switch texture – A floating point value that calls the texture from the Texture List (below in the UI) by the ID number. Interpolate – If the switch value falls between two textures from the Texture list, this interpolate between them. Otherwise, when disabled, the closest texture from the list is used. Loop Through Textures – This option works in Use face material ID and Use object ID modes. When the faces or objects assigned with VRayMultiSubTex map are more than the sub-textures in the map, the Loop Through Textures option goes through all sub-textures and once they finish, reverts to the first sub-texture, continuing until all faces or objects get a sub-texture. In Use object ID mode all objects with assigned ID different than 0 get a sub-texture. The ones with object ID equal to 0 get the Default color. Seed – When the mode is set to Random by node name, this parameter allows the user to change the randomization pattern.
Add New Item – Adds a new sub-texture to the texture list. Used – Enables the sub-texture for rendering. Value – For modes that use IDs, specifies the ID that corresponds to each texture. |
