Exporting Through the Toolbar ButtonTo create a proxy through the V-Ray Objects Toolbar, select the group or component you want to export. The icon will remain inactive until an object in the scene is selected. When you select a group or component in the scene, the Export Proxy button will become active. If you want to export a geometry selection, select the geometry and press the Export Proxy button. From the drop-down menu of the Mode option, choose Proxy Scene, and then press Export. Note that the geometry is exported together with its shaders and lightning. Mode – Allows you to choose between Proxy Mesh (.vrmesh) and Proxy Scene (.vrscene) export. The addition of Proxy Scenes allows you to export a selection of geometry, lights, and special objects combined into a single proxy. File Path – The name of the file. The file is saved in a custom folder, specified by pressing the Save File icon on the right. Overwrite Existing File – When enabled, V-Ray automatically overwrites any existing file with the same name at the specified path. Strip Paths – When enabled, all file paths of the assets in the vrscene are stripped down to file names. Conversion of the paths from absolute to relative allows safe vrscene transfer, as long as its asset files are moved to the same directory. Replace Object with Proxy – If enabled, the source object is automatically replaced with its proxy version. Material assignments are preserved. Export – Exports the .vrscene file to the specified folder. |
