This page provides information about navigation controls in Lavina.
There are various controls to enable you to navigate the scene in Lavina's viewport. Some controls are enabled entirely with the mouse, with the keyboard, or with combinations between the two. The navigation can be set to work as in 3ds Max, SketchUp or Maya from Edit > Preferences > Interaction > Navigation > Preset.
A full list of shortcuts can be found in Help tab > Mouse and Key shortcuts. See the Shortcuts page.
To understand the controls, you should assume the following abbreviations:
Abbreviation | Control |
LMB | Left Mouse Button |
RMB | Right Mouse Button |
MMB | Middle Mouse Button |
The following commands are universal for all navigation presets:
Shortcut | Command |
Ctrl+Alt+LMB | Change Focus Distance |
Ctr+MMB | Roll Camera |
` | Toggle First Person Mode |
C | Toggle Camera Collision |
Alt+Z | Undo Camera |
Alt+Shift+Z | Redo Camera |
X | Level the Camera (resets Camera roll) |
Home | Switch to Home Camera |
PgDown | Switch to Next Camera |
PgUp | Switch to Previous Camera |
Ctrl+F1..F12 | Save Camera Slot |
F1..F12 | Load Camera Slot |
In Fist Person mode | |
W | Camera Move Forward |
S | Camera Move Backward |
A | Camera Move Left |
D | Camera Move Right |
E | Camera Move Up |
Q | Camera Move Down |
Shift+ | Camera Move Faster |
Ctrl+ | Camera Ignore Collisions |
In Normal mode | |
RMB+W | Camera Move Forward |
RMB+S | Camera Move Backward |
RMB+A | Camera Move Left |
RMB+D | Camera Move Right |
RMB+Up | Camera Pan Up |
RMB+Down | Camera Pan Down |
RMB+Left | Camera Pan Left |
RMB+Right | Camera Pan Right |
RMB+Shift+ | Camera Move Faster |
RMB+Ctrl+ | Camera Ignore Collisions |
The following commands have different shortcuts depending on the selected preset:
