This section contains details about Utility Textures found in V-Ray for Rhino.
Utility Textures allow users to perform a variety of helpful functions on texture maps inside a scene (such as compositing textures together and value conversions), as well as provide color corrections option.
A Utility Texture can be replaced with another Utility Texture or any other type of V-Ray texture via the Replace With New Texture () button, which activates when you select the texture to be replaced. If the texture is an instance, all copies are changed as well.
Bezier Curve
Color Correction
Mix Map
Mix Map
Mix Operator
Mix Operator
Mix Value
Mix Value
MultiSub
Simple Mix
Simple Mix
Spline Curve Correction
TriPlanar
