There are multiple options for choosing what engine to render the Solar Study with: V-Ray, V-Ray Vision, Chaos Vantage, and Chaos Cloud. V-RayThe Render Solar Study, exports all frames with different sun positions, as set in Revit, and renders them sequentially. It is necessary to have the Auto-Save (Settings > Renderer tab > Auto-Save) enabled in order to render all frames of the study. Otherwise, only the first frame will be rendered. Specify the file path and type. Image options can also be changed. For more information, see Renderer. VisionLaunching V-Ray Vision loads the sun animation within Vision itself where it can be played or exported in various formats, including video. Chaos VantageSolar Study can also be exported to Chaos Vantage if there is an appropriate system configuration, namely an RTX card. Click Connect to Chaos Vantage and execute the solar study rendering in Chaos Vantage. Chaos CloudSolar Study can also be exported to Chaos Cloud and rendered there. Click Render in Chaos Cloud to execute the solar study rendering in Chaos Cloud. |
