Enabled – Turns on/off the aerial perspective effect. Connect to V-Ray Sun – The Aerial Perspective effect requires connection to V-Ray Sun parameters in order to work accurately. This option is ignored in case other type of environment light is used. Atmospheric Height – Specifies the height of the atmosphere layer. The value corresponds to the units set in the current Revit project. Lower values can be used for artistic effects. View Distance – Specifies the distance at which the fog has absorbed 90% of the light coming from objects behind it. Lower values make the fog appear more dense, while larger values reduce the effect of the aerial perspective. The value corresponds to the units set in the current Revit project. Light Multiplier – Controls the amount of sunlight scattered from the atmospheric effect. The default value of 1.0 is physically accurate; lower or higher values could be used for artistic purposes. Filter Color – Affects the color of the unscattered light. Affect Environment – When disabled, the atmospheric effect is applied only to camera rays that hit actual objects, but not to rays that hit the sky. Affect Background – Specifies whether the effect is applied to camera rays that hit the background in case of a background image. This option is enabled by default, but some interesting effects are possible when disabled. |
