Mode – Specifies the mode in which the color is determined: RGB Color – The color is directly specified by the Color parameter. Temperature – The color temperature (in Kelvin) is specified by the Temperature parameter. Color – This color swatch can be used to visualize the resulting color. It can also be double-clicked to bring up the Color Picker. Temperature (K) – Specifies temperature in Kelvin degrees. Color Multiplier – Specifies a multiplier for the color strength. Color Gamma – Specifies a gamma correction applied during rendering. This does not affect the Color swatch. |
