This is a V-Ray application that is common across all V-Ray installations.
The VRImg to OpenEXR converter is both a command-line utility and a simple GUI application that can be used to convert .vrimg image files to .exr files in OpenEXR format. The .vrimg file format is a special format used by the V-Ray VFB to store the rendered image incrementally while rendering, in full floating-point format, with all available render elements. The V-Ray Image to EXR Converter converts .vrimg files to EXR format so the render elements may be loaded into compositing software, where they can be used for Back-to-Beauty compositing or for other adjustments and fine-tuning at the render element level.
SketchUp Installation
This tool comes with the V-Ray for SketchUp installation. You can quickly open a command prompt in the folder where it is located, or run the executable to bring out vdenoise's GUI.
Windows: start the vrimg2exr executable from C:\Program Files\Chaos Group\V-Ray\V-Ray for SketchUp\extension\tools\vrimg2exr
Mac OS X: start the vrimg2exr executable from /Applications/ChaosGroup/V-Ray/V-Ray\ for\ SketchUp/extension/tools/vrimg2exr.bin
