This page provides information about the Common tab in V-Ray Render Settings in Cinema 4D.
The Common tab of the V-Ray Render Settings provides options for distributed rendering and exporting a .vrscene file.
UI Path: ||Render menu|| > Edit Render Settings... > V-Ray > Common tab
V-Ray Image Output
Use V-Ray Output System – When enabled, you can use V-Ray to set the output image format of the render. Unlike Cinema 4D's output options, V-Ray can output deep .exr and .vrimg files.
Apply VFB Compositing and Color CorrectionsEnable this option to save all applied VFB color corrections to the RGB channel of the output image. This does not apply to the sRGBGamma 2.2 and ICC display corrections. OCIO, LUT and Background Image corrections are saved if this is explicitly specified in their VFB rollouts.
File – Specifies the name of the file to be saved.
Format – Specifies the file format in which the image(s) is saved.
PNG
Compression – Allows you to choose compression level for the resulting file. Lower values mean less compression and larger file size. Higher values mean better compression and smaller file sizes. Note that PNG files use a lossless compression, so the resulting image quality is not affected.
Bits per channel – The number of bits for each of the PNG channels (red, green, blue, alpha).
Alpha Channel to Separate File – When enabled, the alpha channel of the rendered image is saved to a separate file.
Don't Save Alpha Channel – When enabled, the Alpha channels will not be saved (ignored with multichannel exr and vrimg).
Don't Save RGB Channel – When enabled, the RGB channels will not be saved (ignored with multichannel exr and vrimg).
JPG
Quality – Allows you to choose the desired JPEG output quality. Lower values represent smaller file size and worse quality; higher values represent larger file size and better image quality.
EXR
Type – Specifies the exr type to be saved: Multichannel, Deep or Normal.
Compression – Allows you to choose the compression type for the output file:
Default
No compression
 – Disables all compression.
Run-length – Basic form of compression that is comparable to the one used by Targa/BMP files.
Scanline Zip – Zip style compression applied to individual scanlines.
Block Zip – Zip style compression applied to blocks of 16 scanlines at time. More effective then Scanline Zip, but can be slower to decompress.
PIZ – Uses a new combined wavelet / Huffman compression. This form of compression is quite effective when dealing with grainy images, and will often surpass any of the other options under grainy conditions.
PXR24 – Converts data to 24 bit then uses Zip compression. It is lossless for half and 32bit integer data and slightly lossy for 32bit float data.
B44 – This form of compression is lossy for half data and stores 32bit data uncompressed.
B44A – An extension to B44 where areas of flat color are further compressed. Regular B44 compresses uniformly regardless of image content.
DWAA
 – JPEG-like lossy compression format. Compresses 32 scanlines together. 1
DWAB – Same as DWAA, but compresses blocks of 256 scanlines to achieve better compression ratio.
Bits per channel – Allows you to choose between 16-bit (half float) and 32-bit (full float) precision.
Extra Attributes – Allows you to specify additional attributes for the OpenEXR file. These are of the format attr1=val1;attr2=val2;... where the values can be either integer or floating-point numbers, or lists of numbers in brackets representing vectors, matrices etc. For example:
 int_attr=53;float_attr=3.14;vec4_attr=(1, 2, 3, 4)
 If a value cannot be recognized as a number or a sequence of numbers, it is assumed to be a string value.
Auto Data window – Determines what data window information is written to OpenEXR files. This option works only when the Memory frame buffer option of V-Ray is set to Full.
render region – Sets the data window to the render region.
auto – The data window is determined from the pixels that have non-zero alpha values.
whole image – Sets the data window to the image resolution.
Write Integer IDs – When enabled allows you to write ID information in integer form rather than RGB colors.
Multipart – When enabled, multichannel EXRs will be written to a single multi-part file. This feature requires OpenEXR 2 support.
Deep Alpha Colors – Specifies how the alpha is written in the deep .exr file:
Monochrome – One alpha exr channel is generated, called "A";
RGB – Three color alpha channels are generated: "AR", "AG" and "AB" (red, green, blue alpha);
Monochrome+RGB – Generates both the monochrome alpha ("A") channel and the three color alpha channels ("AR", "AG" and "AB").
TGA
Compression type – Specifies compression options for the resulting image.
SGI
Bits per channel – Specifies the desired number of bits per channel (8 or 16) in the resulting image.
TIF
Bits per Channel – Specifies the desired number of bits per channel (8, 16 or 32) in the resulting image.
Interleaved Color Channels – When enabled the color information for each pixel is saved using the Interleaved order which means that the full color for each pixel is saved before moving to the next one. Some image processing applications require that the image is saved in this mode.
VRST
Bits per Channel – Specifies the desired number of bits per channel (16 or 32) in the resulting image
Denoiser
The V-Ray Denoiser takes an existing render and applies a denoising operation to it after the image is completely rendered out via normal means. The denoising operation detects areas where noise is present and smooths them out.
Enable –  When enabled, starts denoising the rendered image in the V-Ray Virtual Frame Buffer.
EngineAllows choosing between the Default V-Ray denoiser and the NVIDIA AI denoiser. Note that, the NVIDIA AI denoiser requires an NVIDIA GPU.
Preset – Offers presets to automatically set Strength and Radius values.
Default – Applies mid-level denoising.
Mild – Applies a more subtle level of denoising than the Default preset.
Strong – Applies a stronger level of denoising than the Default preset.
Custom – Allows the Strength and Radius parameters to be set to custom values.
Strength – Determines the strength of the denoising operation. This value is automatically set by preset selection, but can be changed when Preset is set to Custom.
Radius –  Specifies the area around each pixel to be denoised. A smaller radius affects a smaller range of pixels, while a larger radius affects a larger range, which increases the noise removal. This value is automatically set by preset selection, but can be changed when Preset is set to Custom.
Advanced Denoiser
Use GPU Acceleration – Uses the GPU device(s) to accelerate the denoising calculations. In case there is no compatible GPU device, denoising automatically falls back to use the CPU, even if the option is enabled. When the NVIDIA AI denoiser is used, this option is not available. Note that, the NVIDIA AI denoiser requires an NVIDIA GPU.
Mode – Specifies how the results of Denoiser is saved.
Only generate render elements – All render elements required for denoising are generated so that denoising can be done with the Standalone Denoise Tool or the V-Ray Denoiser plugin for Nuke. The information calculated within them is not applied to other render elements, and no VRayDenoiser Render Element is generated.
Hide the channel with the denoised result in the VFB
 – The Denoiser channel is not present separately in the VFB. The effectsResult channel is generated with the denoised image.
Show the channel with the denoised result in the VFB – The channel is generated to contain a denoised version of the RGB Color Render Element using the specified settings. The original render elements, including the RGB Color Render Element, are not changed.
Distributed Rendering
For more information on distributed rendering with V-Ray, see the Distributed Rendering page.
Use Distributed Rendering – Enables additional parameters and settings needed to distribute the rendering across additional computers. Note: The vray_dr_list.xml file stores the settings information for your DR setup.
Use Local Machine – The client/local machine functions as a render server along with the other computers used to complete the rendering task. Disabling it means all rendering are done on other machines apart of the DR set up.
Ignore in Interactive – When enabled, Interactive only runs on the local machine rather than the whole distributed rendering network.
Transfer Assets – Allows render servers to automatically download missing rendering assets from the client machine,  including textures, V-Ray proxy files, IES profiles, GI solution caches (irradiance maps, light caches), etc.
Render Hosts button – Opens the V-Ray DR settings window.
Render Hosts
These options set the machines V-Ray will use for Distributed Rendering.
Host IP or Name – A text field to enter the name or IP address of the machine to use as a DR server(slave).
Port – Specifies the port number where the DR server operates.
Alias/description – A text field to place notes about the particular DR server.
Add server – Allows a manual way to add a server by entering its IP address or network name.
Remove –Deletes the currently selected server(s) from the list.
Toggle – Toggles the state of the selected server(s) between enabled and disabled.
Edit – Modifies the information for the selected entry in the list.
Translator
Render – Enables V-Ray to render the image to the frame buffer and then save an image file as specified in the Common tab of the Render Settings window. This option can be used at the same time as Export to a .vrscene file.
Export to a .vrscene file –  Enables V-Ray to export the scene to a .vrscene file and expands the options in the rollout. For more information on the .vrscene export, refer to the Exporting V-Ray Scene Files page.
Separate files – When enabled, V-Ray exports separate files for different components of the scene. This also allows you to disable export for certain types of objects.
Each frame in separate file – When enabled, V-Ray makes a separate file for each rendered frame.
Strip paths – When enabled, the paths for assets (bitmap textures, proxies, GI caches loaded from file, etc.) are removed from the exported file and only the file names of the assets remain.
Write mesh data in hex format – When enabled (the default), the mesh data is written in hexadecimal format in the .vrscene file. This makes the files smaller and faster for processing, but less readable to a user. When disabled, the mesh data is written in normal decimal format.
Write transform data in hex format – When enabled (the default), transform data is written in hexadecimal format in the .vrscene file. This makes the files smaller and faster for processing, but less readable to a user. When disabled, the data is written in normal decimal format.
Compressed – When enabled, basic compression is applied to the .vrscene file. This option can only be used together with Write mesh data in hex format.
Export Lights – Enable/disable the export of lights. Available when the Separate files option is enabled.
Export Nodes – Enable/disable the export of nodes. Available when the Separate files option is enabled.
Export Geometry –  Enable/disable the export of geometry. Available when the Separate files option is enabled.
Export Materials –  Enable/disable the export of materials. Available when the Separate files option is enabled.
Export Textures –  Enable/disable the export of textures. Available when the Separate files option is enabled.
Export Bitmaps –  Enable/disable the export of bitmaps. Available when the Separate files option is enabled.
File name – Specifies the location and name for the .vrscene file.
V-Ray Frame Buffer
Image Effects Update Freq.Controls the regularity of updates during the progressive rendering. Specifies roughly the percentage of the time effects like denoising and/or lens effects are allowed to take compared to the frame render time. A value of 0 disables updates during the progressive rendering, whereas larger values cause the effects to be updated more frequently; 100 causes updates as often as possible. Values ranging from 5 to 10 are usually sufficient. The resulting effects are saved as the EffectsResult render pass, which appears when the Denoiser or Lens Effects are enabled.
Autoswitch to Effects Result With this option enabled V-Ray Frame Buffer automatically displays the effectResult channel after calculation of post effects is done. When disabled, the RGB color channel is displayed instead.
  1. When included in a multichannel EXR, Sampler Info and Cryptomatte render elements are always saved with lossless compression. ExtraTex has its own parameter for disabling lossy compression like DWAA/DWAB.
