These parameters are available when the Mode is set to CDLTransform. Slope rgb – Multiplies for the red/green/blue color components. Offset rgb – Offsets for the red/green/blue color components. Power rgb – Gamma values for the red/green/blue color components. Saturation – The saturation value; 0.0 makes the image grayscale. Use file – When enabled, the CDL parameters are read from a .cc or a .ccc file instead of specified directly. File – Specifies a .cc or .ccc file to read. Cccid – Color correction id as specified in the color correction file. Direction – Specifies whether the forward or the inverse CDL transformation will be applied. Save cc – Allows the CDL parameters to be saved in a .cc file. get values from file – When Use file is enabled, this button copies the parameters from the file into the texture parameters so that they can be adjusted if needed. |
