This page provides information on the Coat Glossiness Render Element.
The Coat Glossiness Render element is analogous to the Mtl Reflect Glossiness Render Element. This channel holds a float number with the value set in the Coat Glossiness parameter in the VRayMtl Coat Layer.
VRayVFB – When enabled, the render element appears in the V-Ray Frame Buffer.
