Chaos Player has shortcut keys for almost any command you will ever use. In addition to the defaults, users can set their own custom shortcuts.
Default Shortcut Keys
The following table lists the default keys and their function.
Shortcut Key
Command
Ctrl + Delete
Delete selected layer
Ctrl + A
Select all layers
Shift + Page Up
Move selected layer up in the layer stack
Shift + Page Down
Move selected layer down in the layer stack
Shift + Home
Move selected layer to the top of the layer stack
Shift + End
Move selected layer to the bottom of the layer stack
Ctrl + DDeselect layer
Esc
Deselect layer
Left
Go to previous frame
Right
Go to next Frame
Home
Go to first frame
End
Go to last frame
Space
Pause
Enter
Pause
Play backward
Up
Play forward
L
Play forward
J
Play backward
KStop
Shift + LJump 10 frames forward
Shift + KJump 10 frames backward
Numpad *
Increase fps
Numpad /
Decrease fps
C
Disable/enable layer color corrections
Shift + C
V
Toggle layer visibility
Shift + V
FToggle full screen
Q
Show/Hide layer stack
D
Toggle the blend mode of the selected layer between Normal and Difference
Alt + Home
Set the Work Area beginning at current frame
Alt + End
Set the Work Area end at current frame
I
Go to the selected layer’s In Point
O
Go to the selected layer’s Out Point
Shift + I
Place In point at current frame
Shift + OPlace Out point at current frame
B, Alt + B
Show blue channel in grayscale
G, Alt + G
Show green channel in grayscale
R, Alt + R
Show red channel in grayscale
A, Alt + A
Show alpha channel
Alt + L*
Show luma channel
Z
Show depth channel
Shift + B
Show blue channel in color
Shift + G
Show green channel in color
Shift + R
Show red channel in color
Align layer’s In Point at current frame
Align layer’s Out Point at current frame
Alt + [
Alt + ]
Alt + Left
Move selected layer to the left in the time line
Alt + Right
Move selected layer to the right in the time line
Alt + Up
Alt + Down
Alt + DSelect none
Ctrl + D / cmd + DSelect none
Ctrl + F / cmd + FFlip horizontal
Shift + FFlip vertical
Numpad 5
Toggle zoom factor between 100% and Fit Window
Ctrl + Numpad 5
Reset layer position
Numpad +
Increase zoom factor
Numpad -
Decrease zoom factor
Ctrl + Numpad +
Ctrl + Numpad -
Shift + Left
Move selected layer to the left in the work space
Shift + Right
Move selected layer to the right in the work space
Shift + Up
Move selected layer upwards in the work space
Shift + Down
Move selected layer downwards in the work space
Shift + A
Sets the work area to match the selected layer
Ctrl + Shift +H
Start the built-in http server
F5
Update all layers
F11
Toggle full screen
F12
Toggle full screen
Tab
Show/hide the time line
Ctrl+ Shift+ Left
Move selected layer half its width to the left
Ctrl+ Shift+ Right
Move selected layer half its width to the right
Ctrl+ Shift+ Up
Move selected layer half its height upwards
Ctrl+ Shift+ Down
Move selected layer half its height downwards
Shift + D
Duplicate layer
Ctrl + Shift + D
Duplicate and split layer
Show/hide the property panel
Ctrl + V
Paste the contents of the clipboard as a new layer
Ctrl + Shift + V
Paste the contents of the clipboard as a new Still Image Layer
Ctrl + Alt + V
Paste the image on the clipboard as a new Embedded layer, ignoring other formats
Ctrl + C
Copy the current frame of the selected layer to the clipboard
Ctrl + Shift +C
Copy an image of the mask contents to the clipboard
Ctrl + Alt + C
Copy an image of the window contents to the clipboard
F8
Resize window to fit Work space
Show/hide information bar
Ctrl + L
Add layer
U
Update frame
Shift + U
Update modified frame
Ctrl + Shift + U
Toggle automatic update
F3
Previous image of a sequence in a still image layer
F4
Next image of a sequence in a still image layer
Ctrl + O
Open Composition
Ctrl + S
Save Composition
Ctrl + Shift + S
Save Composition As…
Ctrl + T
Create new text layer
M
Flip layer horizontally
Shift + M
Flip layer vertically
Ctrl + Z
Undo
Ctrl + Shift + Z
Undo
K
Crop layer
Shift + K
Crop layer
Shift + Space
Preload layer to cache
Shift + Esc
Stop preload
Toggle Preview Area tooltip
Shift + Alt + Left
Set the target view for the layer to Left
Shift + Alt + Right
Set the target view for the layer to Right
Shift + Alt + Down
Ctrl + Alt + Left
Display the left view
Ctrl + Alt + Right
Display the right view
Ctrl + Alt + Down
Display both views
Ctrl + Alt + Up
Switches the left and right view
Ctrl + Shift + GAssign a new group to the selected layers
NOTE: The hotkey for Show Luma Channel is updated to Alt + L since Chaos Player Update 1 (version 2.10.00). IF you are using an older version of Chaos Player, the hotkey for this option is L.
Custom Shortcut Keys
In addition to the default shortcut keys, you can define your own. The default shortcut keys are defined in a file named keydefs.txt that can be found in the config folder of the installation directory. The default locations are
You can create your own set of custom shortcut keys by creating a file named keydefs.txt in the user folder of the installation directory and adding your shortcut keys using the commands listed in the Commands Reference.
