Full Screen Mode – Toggles the full screen mode. Timeline – Shows/Hides the timeline area user interface. Layer Stack – Shows and hides the layer stack. Information Bar – Shows/Hides the information bar. Layer Properties – Shows/Hides the layer properties panel. Pixel Info – When enabled, the toolbar displays information about the pixel that the mouse is currently hovering over. This includes X and Y coordinates, RGB color and HSV color values. Safe Area – Shows/Hides the resolution mask in the preview area. Grid – Shows/Hides the workspace grid. Synchronize Display – Toggles the vertical synchronization. Prevents tearing but will have a performance hit. Reset/Fit to Window – Resets the workspace pan to the default 0, 0 position and the zoom to 100%/ Fits all visible layers to the preview area performing pan and zoom at the same time. Zoom In – Zooms in the workspace in steps (10%, 20%, 30%, 50%, 100%, 200%, 400%). Zoom Out – Zooms out the workspace in steps (10%, 20%, 30%, 50%, 100%, 200%, 400%). Resize Window to Fit – Resizes the Chaos Player window to fit all viewable layers. Toggle Red Channel – Toggles the visibility of the composition’s red channel in grayscale. Toggle Green Channel – Toggles the visibility of the composition’s green channel in grayscale. Toggle Blue Channel – Toggles the visibility of the composition’s blue channel in grayscale. Toggle Alpha Channel – Toggles the visibility of the composition’s alpha channel in grayscale. Toggle Luma Channel – Toggles the visibility of the composition’s luma channel in grayscale. Toggle Red Channel Mode – Toggles the visibility of the composition’s red channel in color. Toggle Green Channel Mode – Toggles the visibility of the composition’s green channel in color. Toggle Blue Channel Mode – Toggles the visibility of the composition’s blue channel in color. |
