The Text Property Panel allows you to adjust the text mark-up annotations.
The text in text layers may contain embedded fields of the form {object:property}
. Such fields are replaced with their values before the text is displayed.
For example, {timeline:frame}
is replaced with the current frame, and {4:timecode} is replaced with the embedded timecode of layer 4.
This is useful for burn-ins when creating previews and dailies.
For more information about the syntax check the Text fields reference.
Chaos Player set with frame number in the text field.
