This page provides information about the V-Ray Scatter Components in Grasshopper.
V-Ray Scatter tab stores the following Scatter components for creation in Grasshopper: V-Ray Scatter 2, V-Ray Scatter Area Modifier, V-Ray Spline Scattering, V-Ray Surface Scattering, V-Ray Volume Scattering, and the 3D Domain Components.
V-Ray Scatter 2 – Creates instances of the input V-Ray Geometry Guest objects based on various distribution controls. The number of scattered instances depends on the density which is number of instances per square unit.
V-Ray Scatter Area Modifier – Scatters Guest objects everywhere on the Host objects, except for or exclusively in the areas defined by objects from this component. Used as V-Ray Scatter 2 component’s Area Modifier input.
V-Ray Spline Scattering – Creates instances of the input Scatter 2 Guests scattered along splines (Scatter 2 Hosts). Used as a V-Ray Scatter 2 component’s Scattering Configuration input.
V-Ray Surface Scattering – Creates instances of the Scatter 2 Guests scattered on surfaces (Scatter 2 Hosts). Used as a V-Ray Scatter 2 component’s Scattering Configuration input.
V-Ray Volume Scattering – Creates instances of the input Scatter 2 Guests scattered inside the object's bounding box (Scatter 2 Hosts). Used as a V-Ray Scatter 2 component’s Scattering Configuration input. Keep in mind that bounding boxes are cube-shaped, therefore using this mode on a round object scatters instances in a cube around it.
Construct Domain 3 – Creates a three-dimensional domain from six numbers. Used as a Scatter 2 Random Translation, Random Rotation and Random Scale input.
Construct Domain 3 – Creates a three-dimensional domain from three simple domains. Used as a Scatter 2 Random Translation, Random Rotation and Random Scale input.
Domain 3 – Contains a collection of three-dimensional domains. 3D Domains are typically used to represent volume fragments. A three-dimensional domain consists of three one-dimensional domains. Used as a Scatter 2 Random Translation, Random Rotation and Random Scale input.
Rhino8_VRay6.2_GH_Components_Scatter2_Tab
Example Connections
Here is an example of how the Scatter components are connected.
